Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
The ON button is the only button that responds. Which means that once it is on I cannot press "2nd" and then ON because the ON button is the only button that works. I need to take off the batteries so the calculator turns off.
I fixed my calculator, but i am not sure how I did it. I just took it apart, put the circuit board to a fan, wiped it, and put it back together. Then when I turned it on I pressed "2nd" first then it started working.
Posted on Jul 20, 2009
Dell 1900FP - UltraSharp - 19" LCD Monitor reset
Nice you asked me. I have a 23" version sitting right next to me. Push any side button. Then press the 3rd button once. Press the 2nd one 4 times, then the 3rd once. Press the 2nd 7 times, then the 3rd once (maybe twice to confirm).
Apr 06, 2014 | Computers & Internet
Replaced battery now nothing works,doors dont unlock,car doesnt start,no sounds when pressing buttons although it still sang when battery replaced,pressed "P" button hoping it would do something and now it...
The waves mean that the remote is vibrate mode. Try reprogramming the remote. Open the door, turn ignition on, press and release the valet button once then, press and hold the valet button. press the lock button on the remote. Vehicle should respond with a chirp from the siren. Release valet button, turn off ignition, test system.
Jan 17, 2014 | Directed Electronics 479V Remote Gen 2...
Where is my "e" button
If you mean the base of the natural logarithms, there isn't a key to give its value directly. It can be calculated by raising e to the first power by pressing 2nd [e^x] 1 = . [e^x] is on the third key in the leftmost column.
If you mean the exponent of ten, [EE] is the fifth key in the second column.
Apr 08, 2013 | Texas Instruments TI 30XIIS Scientific...
Flashing cf after carrier ac turns off
Here is an Article that I found that has some useful information for you. http://airmaster.net/troubleshooting/carrier-window-room-air-conditioner-troubleshooting CF means Cooling Fail.
Check us out online at AC Services Boca Raton
Mar 12, 2012 | Carrier Heating & Cooling
Need intructions how to program remote control on vip722k second receiver
Press and hold down the SETUP button located on the remote. Wait until the INDICATOR light turns on. It will blink once the button is pushed, however once you see the indicator light stay one, release the button. Click the button to the DEVICE you wish to program. If it is a TV, then click the TV button. If it is the cable box, then click CBL button. After doing so, the indicator should still stay on. Press the DOWN CHANNEL button several times until you see the RECEIVER yo wish to program respond. Example: If it is a TV, then you will notice the CHANNEL change once the remote locates the correct settings for that receiver. If you see the receiver respond and you are pushing the down channel button but nothing is working, it means you passed the internal settings of the remote to the receiver. Try pushing the CHANNEL UP button slowly. It may be able to relocate the the proper settings. Once you see the channel change again, press ENTER to program the remote. If this fails, retry the same steps. In some cases you may miss the correct internal settings.
Nov 23, 2010 | DISH Network IR Remote Control
What does the Error 5100 code on my printer mean?
If this does not work for your model revert back to me along with your model number
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Jul 24, 2009 | Canon Office Equipment & Supplies
Hi my name is Christy I need the codes for my remote control model rcr311w r55n7 4747p,how to program the remote to my sonya tv? HELPPPPPP
If you mean Sony .. its 002
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Jan 07, 2009 | RCA RCR311B Remote Control
Screen frozen calculator not responding to buttons pressed.
give it a factory reset, this works, you will lose any unarchived data : http://www.associatedcontent.com/video/265/how_to_reset_a_texas_instruments_ti89.html?cat=59
Aug 30, 2008 | Texas Instruments TI-89 Calculator
Mean (x-bar), variance (s^2) and standard deviation (s)
Enter 1 then press the (SIGMA)+ button (SIGMA) looks like a sideways capital M ....its a Greek letter.
Then enter 2 and press the (SIGMA)+ button
Then enter the next value and press the (SIGMA)+ button
After you press the (SIGMA)+ button the calculator displays the number of numbers you have entered
Once all numbers of your sample have been entered press 2nd and the button corresponding to x-bar
sample st. dev is the (sigma)n-1 button (need to use 2nd button)
variance is (std. dev.)^2
population st. dev is the (sigma)n-1 button (need to use 2nd button)
Jan 18, 2008 | Texas Instruments TI-30XA Calculator
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
143 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
