Question about Leisure HOMEPRIDE Electric Fireplace Heater w/ Remote
I have a marco firplace model 7927740 no manuel..need to know how
To close draft due to water leaking in fireplace. What is the lever on the right side and what's it's function? Thanks
  • 297 Answers
The lever is the fresh air port to outside.
Posted on Jul 15, 2009
  • glo1960 Nov 07, 2010
    can we use a wax log in this model fireplace
The fireplace no longer produces a flame, i do not have the manual to trouble shoot and fix it
Gas Fireplace Manual - Gas Fireplace Instructions: Mendota ...
mendotahearth.com/gas-fireplace-stove-owners-manual.php
Mendota gas fireplace manuals and gas fireplace instructions for Mendota ...Mendota Gas Fireplace Insert FullView Model FV33i PF2 - Installation Manual
[PDF]FIREPLACE HEATER - Crane
crane-usa.com/assets/.../Fireplace_Heater_2013.pdf
by C Care - ‎Cited by 2 - ‎Related articles
your fireplace heater, please contact Crane. Customer ... This instruction manualapplies to the following models of the Fireplace Heaters product line: Color.
Nov 29, 2015 | Heating & Cooling
When the marco fireplace vent supposed close or open?
It is to be closed in the burner off cycle , this is so to reduce heat losses due to a draft letting the heat rise out of the unit.
Feb 14, 2013 | Leisure HOMEPRIDE Electric Fireplace...
Inbuilt fireplace smoking
if its a tall fire place you need to start the draft by lighting a news paper and holding up into the chimeney opening also make sure these not a nest up on the top of the flew
Apr 30, 2012 | Garden
We have a GTi model 5000 GDV gas fireplace that is on the outside wall and is about sixteen years old. We have never used it we bought the house when it was nine years old. This year we decided to use it....
Sorry to read about your problem, I hope this helps you out.
well first, clean out the vent exhaust. after all those years, who knows whats inside...you must have burned off dirt and dust. unless the unit has fans in it and they are defective....
I suggest to contact a service company
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 28, 2010 | Heating & Cooling
I want to know what a lever in a fire place is
The lever at the top of the fireplace operates the "damper". The damper is a door that opens the fireplace to the outside via the chimney.
The damper must remain open whenever a fire is burning in the fireplace to allow smoke to escape out the chimney instead of filling the fireplace and eventually, the room. The damper should be opened prior to starting a fire, otherwise the handle will be too hot to handle. Once the fire has gone completely out, the damper should be closed to prevent heat from being drawn out of the room / home. You can easily check is your damper is open or closed by simply looking up the chimney. If dark, it is closed. If light(er) it is open. Do not operate the damper while looking up - as dirt, soot, rust, etc. can fall when doing so.
The damper also prevents pests from enter the room / home. It is not uncommon for birds, bats squirrels, etc. from creating a home / getting caught in side the chimney.
I hope this helps - good luck!
Nov 12, 2010 | Coleman Heating & Cooling
I think my relief valve broke because my water was turned off because of a leak and when the handyman (not a plumber) fixed the leak, he may have turned the water pressure up too high and had nothing to...
This is one possible solution. Not knowing the type of plumbing pipes you have or where the leak was makes it hard to give you a solid answer. Some people will open the t&p valve to aid in draining water out of piping to facilitate repairs. There is a small lever in the center of the t&p valve that should be at 90 degree angle to front surface of a valve mounted on side of tank. If it's straight out it is open. Push down on lever to close it. If it was opened and then closed it may not have shut off completly due to mineral build up around valve seat.If it is open then close it and turn water supply back on. If it is closed you can turn water supply on and using wooden hammer handle or other light tool tap directly on center of valve. Do not hit it very hard. If it has been opened and failed to seal you should see a reduction of flow rate fromt&p valve. Either way youshould have t&p valve replaced as it should olny open due to extremely hot water which also will cause increase in pressure. Hope this helps. Thanks.
Nov 09, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Drain pipe leaking on outside of home from hot water heater,? cause
You have a safety valve which is made to relieve pressure in the hot water heater in case it overheats. It may have developed a leak. Sometime you can lift up the valve and close it again a few times and it will reseal otherwise replace it. It's on the top of the heater with a small lever. Usually made of brass.
Mar 25, 2010 | Fasco Bradford White Hot Water Heater...
Water leak after use from sub-zero water tap
Water valve is not closing completely due to mineral buildup or low water pressure.
eric
Jul 01, 2009 | Frigidaire FRS26R4A Side by Side...
Heating & Cooling Logo
695 people viewed this question
Top Leisure Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
Are you a Leisure Heating and Cooling Expert? Answer questions, earn points and help others
