Swingline GBC Fusion 5100L 12" Laminator Logo
K
Kris Posted on Oct 05, 2015
What is an e4 error
I was running an item through to be laminated and it stopped in "mid-lamination" ~ error code came on , machine beeped, and reversed my item.
2answers
Do I insert the printed paper into clear pouch & just put these 2 items into Smith Corona Laminator LX900? Do I need a heavy paper protector to surround these 2 items? How do I order a protector?
use what is called laminating pouches
you put what you want laminated in the pouch, centre it so that the edges all have the same space, wait until the green light on the laminator appears and enter the pouch with the folded end in first.
It will slowly move through and seal off as it goes
make sure that the pouch is entered square to the rollers or it will crease the finished product or jam the laminator
there is no need for any additional equipment
WHY DOES LAMINATOR KEEP FLASHING E4
I called Swingline and they told me to unplug the machine for 45 minutes to an hour, and then try again. (This resets the machine supposedly.) If there are additional problems, I was told, you may have to look into warranties, etc.
How do i fix laminator with error code E4
I know it is late but here the answer of your problem.
Erreur E4 with the Fusion 5000, you must turn off and disconnect the plog from the wall and wait for 24hours then the erreur disappear.
got this answer from this website : www.e-plastifieuse.com
E-Plastifieuse
Laminator will not stop beeping
We just brought home a new Royal Sovereign Laminator. Plugged it in and turned it on. It will not stop the loud, annoying beep and is stuck on reverse. It's going right back to the store for a refund. Will not ask for another Royal. If you can't make it right, don't try to sell it!
4helpful
Error code E4 for a swinling 5000L
Disconnect it from the power supply for at least half an hour. According to their support people this should solve the problem...
2answers
Pouch stuck in laminator
Firstly switch off the laminating machine and plug out. Turning off the machine will prevent the motor from burning out. As the motor is not burnt, there is no need to repair or substitute the machine.
* When the machine gets turn off look for the damage instantly, if any. If any huge item was inserted to laminate, it might have happened that the item had stuck in the machine. First of all, try to pull out the item gently from the machine. Also, remember that thick and three dimensional items should not be laminated in the laminating machine.
Hotmail Support ' Aol Support
2helpful
2answers
E4 error code
Here is a list of all swingline laminators manuals.
Find the type you have and just look in the manual if they have error's fixing instructions. Plus it is always great to have the manual:
http://www.swingline.com/swingline/us/us/s/2691/manuals.aspx
9helpful
3answers
2answers
Lam Error/Out
I contacted fargosupport.com and a technician walked through the solution, free of charge.
Top Swingline Office Equipment & Supplies Experts
Paul Bade
Arnie Burke
Arnie Burke
vince
Are you a Swingline Office Equipment and Supply Expert? Answer questions, earn points and help others
