Question about Danby DMW139 Microwave Oven
Were are the magnetron ???
We have same microwave and we have problem ... We removed up cover on face and start the microwave ... There are sparks fire at right back ... Is it magnetron there ???
Thanks for your help
  • 744 Answers
HI,
this will require the skilled hands of a qualified tech. the damaged part here is the Magnetron assembly. this is a very sensitive part that creates radiation and the heating process as well. you will need to replace this device asap if possible...
thank u
rate me
Posted on Jul 13, 2009
Microwave made a pop noise and just stopped working? itys not respoding at all?
If there is spark please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is leaking and sparking to the ground. As you have mentioned it was stored, it is quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Now switch the microwave power on and use a cup of water to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. Replace with same type. If not check the waveguides within the cabin for food particles that can burn and spark, check for rust that can corrode and spark when the ceramic paint has worn out.
If there is heating without any issues, you can use the microwave safely
Click on replacing waveguides: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Feb 12, 2013 | Microwave Ovens
My Panasonic Microwave Stops Shortly after I start it. Why?
Feb 01, 2013 | Panasonic NN-P295SF Microwave Oven
Viking vmos200 sparking
Jan 31, 2013 | Viking VMOS200 Microwave Oven
FAULTY MAGNETRON
Jan 30, 2013 | LG MB3949G Microwave Oven
Loud crack noise maytag microwave oven
Jan 29, 2013 | Whirlpool GH8155XM Microwave Oven
Kenmore microwave is sparking when you it start and then goes to pause
see this steps and fix it. God bless you
If you see arcing or sparking inside a microwave, turn unit off immediately. Arcing can be caused by having something metal in the oven cavity touching a side, an oven shelf is touching the side of the cavity, an oven shelf support has broken, microwave waveguide, or bad magnetron.
If your microwave has a shelf in it, and you do not use it, keep it out. If one of the shelf supports breaks or comes out, the microwave will arc where the support was. You will have to sand the spot down, paint with appliance paint and re-install support. If the shelf shifts on the support and touches the side it will arc.
Your magnetron waveguide will either come out of the top, or side of the oven cavity. Some will have a stirrer in it(mostly top waveguides) with a panel over, or just a cardboard type cover over it. Over time, the stirrer cover can become warped from the heat which will expose the stirrer's metal shaft which will then cause sparking. These covers and stirrers come in a kit and can be replaced from inside the oven cavity.
Your cover over a side waveguide is coated with a substance on it, and overtime this coating can come off from the heat and moisture in the microwave. These waveguide covers are very easy to replace from inside the oven cavity. Touch up any paint that may have chipped or come off because of the arcing.
If your waveguide cover and/or stirrer are all OK, then the spark is coming from your magnetron. The antenna on your magnetrom has overheated and burned, sending the microwaves out at the wrong angle. If you catch this microwave oven repair early enough, you can usually get by with just replacing the magnetron. If the arcing has caused servere damage inside the waveguide, you will need a new microwave. Waveguides are not replaceable and most you can barely see into them, let alone sand and re-paint. In this case of microwave oven repair, when you remove the magnetron, you will see the burned antenna, or your magnetron will fail the test below.
see the guide for test the magenetron and another component.
Oct 03, 2012 | Kenmore Microwave Ovens
Sparks when starting then goes to pause mode
see this next steps. God bless you
WE HAVE A KUPPERBUSCH MICROWAVE WHICH HAS STARTED TO SPARK WITH A STRONG SMELL OF ELECTRICS BURNING INSIDE IT WHEN TURNED ON. WOULD LIKE SOMEONE TO LOOK AT IT. WE LIVE IN CO. ARMAGH, NORTHERN IRELAND AND...
Somtimes the wave guides with food particles can burn and smoke if so replace the wave guide.
Also remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Now keeping clear switch on , use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues , you can use the microwave safely
Jul 27, 2011 | Microwave Ovens
Hello! Everytime I start my Whirlpool microwave, it makes a loud crackling noise and I'm worried it's going to start sparking. Is there any way to fix this issue, or is it shot?
The cracking spound is the spark jumping. so if there is spark please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is leaking and sparking to the ground. As you have mentioned it was stored, it is quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
Dec 20, 2010 | Whirlpool Microwave Ovens
My ge is sparking inside. There's a screw not covered and I covered it and still sparked.
I think the magnetron is leaking with traces of open metal exposed out. It will be better to clean the cabin throughly and make sure that there aren't any exposed parts.
If the sparks are still coming in then remove tthe magnetron and check for signs of spark marks on it , if so it must be replaced.
Make sure that the wiring is intact and there is no foreign particles stuck within the magnetron.
Aug 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Danby DMW139 Microwave Oven Logo
126 people viewed this question
Top Danby Microwave Ovens Experts
Andrew Taylor
Andrew Taylor
Ruth summersides
Are you a Danby Microwave Oven Expert? Answer questions, earn points and help others
