Question about Adobe Photoshop 7.0 for PC
Exclamation mark in edit mode
I get an exclamation mark in edit mode. The clip cannot be played or recorded. The thumbnails are black. what do I do?
  • 233 Answers
Re: Exclamation mark in edit mode
Try renaming the file with a standard file name type such as Windows Media Audio/Vidio file .wmv
Posted on Nov 17, 2007
0 characters
3 Points
Windows Media Player has stopped playing/burning?
try to read first Windows Help and support.
search for Burn a CD or DVD in Windows Media Player
or look link Microsoft Community Microsoft Windows
Dec 19, 2014 | Microsoft Windows Media Player
I have Magix movie edit pro 2013. I am making a movie and it will play the audio of a certain track but not the video. what is wrong and how do i fix it. Anytime, i try to play this one clip, the...
On the timeline mode you will see all the tracks laid out. At the start of each one you will see a load of icons - S M and a padlock. On the video track make certain the M (for mute) is not selected. To be certain press play on the video monitor screen and then click the M for the video track. If it was selected the picture should come back.
If that isn't the problem it might be that your computer doesn't have the memory to cope with the video editing software. You can check this out by looking at the bottom left of the timeline mode screen. You will see the word CPU. When the video plays the number will increase. If it goes above 50 you might have problems. If it is at 70+ you have serious memory problem dealing with videos.
Dec 05, 2014 | Magix Graphics Publishing, Design &...
How do I remove a tumbnail from a photo?
Once you've added you're photos, you can set a different photo to act as thumbnail (the programme automatically chooses the first photo/slide, indicated by a little green ticked box sign).
To change the thumbnail to a different photo, highlight the photo you want as thumbnail by clicking it - the frame will change to yellow - and then click on the green ticked box command ("Set Thumbnail") at the top of the window.
You cannot alltogether delete the thumbnail, because every slide show you create needs to have a thumbnail to link the slide show to the menu screen at the start of your DVD. So, on your menu screen there will always be at least one thumbnail. (The black thumbnail that appears in the middle of your screen when you first open the programme, is a "place holder". It needs to be there and it cannot be deleted. Once you've created a slide show, it will be replaced with the photo you have chosen to be the thumbnail. Every time you create a new slide show, a new thumbnail will be added to your menu screen. The position of thumbnails can be changed, using the second ("Edit") Tab.
You will find a User's Guide on the install disc. It can be accessed by inserting the install disc and clicking on the relevant link, or you can right click on your CD/DVD drive (in "My Computer") and then click on "Explore" to look for it on the install disc - it's a pdf file.
Jan 27, 2011 | Individual SlideShow Expressions
Sudden appearance of blue exclamation marks in place of stills
Where did you save your video clips? the clips you trying to used for editing. I suggest to you to import the video clips again and then after that open your project again. Check if still there is a blue exclamation points.
Nov 11, 2009 | Pinnacle Studio Ultimate 12 for PC
Missing photos
One solution is that the pictures Have been moved or their directory re-named while Studio was closed.
Nov 09, 2009 | Pinnacle Studio Plus 12 for PC
Sonar 4 and midi sound cuts offat start of playback
If you are recording from bar 1 at time 1.00 you might want to start recording one or two bars later. So try starting your song on bar three istead of bar 1
Mar 22, 2009 | Cakewalk SONAR 4 Producer Edition for PC
When recording live feed from various guitars I can't get the recordings to synchrinize
Sounds like you have a latency problem. This can be for a variety of reasons, something Cakewalk admits. The reason for that could be everything from processor limitations, not enough RAM, your soundcard, or simply that you need to change the latency configuration in the audio settings menu of the program. Considering that that is the cheapest fix, try changing settings first. Be sure to follor the help information in Cakewalk - they can be a little confusing for Cakewalk (I have no idea why they can't seem to explain their programs after all these years) but you will be able to figure out what settings are right for you.
My guess is that when you record, you are listening to the previously recorded track, and playing to it. Then when you play it all back as a mix, they are not in sync as when you were recording them.
If that is not the problem, plesae explain further. You are able to monitor your previously recorded tracks, right? Not just playing each track "blind" and trying to have them match? Hope not. That is rarely possible - if at all.
If you are monitoring your prerecorded tracks while recording on top of them and it sounds different when you play it back, it's definitely latency.
Oct 02, 2008 | Cakewalk SONAR 4 Producer Edition for PC
Sonar Producer 6 - Audio/midi devices/controller-surfaces..Which settings??
o always run at 0 on play back recording -3 with drums use anlog cables then select anlog 48000 24 bit if u can if its digital cable might use 96000 bit rate ok spdif watch it close on digital for digital clips never go in red keep steady balence cheak your sorse tape how loud is that adjust your stuff to sound good at peaks never hit red in digital mode does this help sum
Mar 13, 2008 | Cakewalk SONAR 4 Producer Edition for PC
Adobe Photoshop 7.0 for PC Logo
259 people viewed this question
Top Adobe Graphics Publishing, Design & Multimedia Software Experts
Laxman Bisht
Laxman Bisht
Are you an Adobe Graphics Publishing, Design and Multimedia Software Expert? Answer questions, earn points and help others
