My fan wont spin - Heating & Cooling
  • 11,896 Answers
Either there is a faulty relay or bad capacitor that is controlling fan motor. bad motor is also possible
Posted on Jul 13, 2009
Duo therm rv air conditioner fan wont spin
If the motor gets real hot you should be able to have it removed and tested---better to replace if bad than rebuild in most cases.
Jun 16, 2012 | Heating & Cooling
How can you tell if clutch fan is out on a toyota4runner
when the engine is cold spin the fan with your hand, it should spin freely.With engine at operating temp shut the truck off and spin the fan it should be tight and wont spin.
May 19, 2012 | 1991 Toyota 4Runner
Fan wont spin, hums. i turn blade by hand fan spins for a while then stops
Replace the fan motor capacitor... if that does not correct the problem, then replace the fan motor...
heatman101
Jul 23, 2011 | Heating & Cooling
When pluged into outlet fans spins and doesnt stop, wont boot
Fan spinning hard is usually a CPU issue.
If you've made any hardware changes to your computer, undo them. This happened to me when I was trying to upgrade my Processor (CPU) and I had the wrong kind.
Mar 09, 2010 | HP Pavilion m7560n PC Desktop
Fan on outside heat pump wouldn't spin put in new cap and started working when got off work it wasn't spinning again
I have a ruud gas pack, the blower fan wont come on. If we go out there we can spin it and she will run, but when the time shut off, so does the fan.. and it wont restart
Jan 28, 2010 | Ruud UBHC Air Conditioner
My ps2 wont play any games
the fan is dead so is over heating and so the cd wont spin
Mar 31, 2009 | Sony PlayStation 2 Slimline Console
Fan on alternator wont spin
I think you should check your connections on the back of the altenator, something is wired incorrectly, if necessary hook up one wire at a time and see what you get. There should be only one large red wire on the BATT connection, and the rest should be in a molded clip that plugs into the altenator, check and ensure that they have a good connection when you hook them up.
Mar 20, 2009 | 1992 Oldsmobile 88
The fan hums wont turn goodman air conditioning
If you are talking about the fan on the outdoor unit, let's try some things.
Kill power to the outdoor unit. Use breaker or disconnect. Now see if the fan will spin with no power going to the unit. If not, bad bearings. Fan D.O.A. If it does spin, good.
Now restore power and turn unit on. If fan runs now, it has a defective or damaged winding. Needs replacing. If it does not start running, most likely the capacitor is D.O.A. or the fan is "Electrically" locked up. Again, fan D.O.A.
If you do replace the fan motor, be sure to always replace the capacitor. It's usually only a few buck more.
Also, be extremely careful when trying to spin that fan. It may take off and take a finger with it. NEVER try to spin the fan with power going to it.
This is no joke, it's dangerous if you don't know what your doing.
It may well be worth having a tech check things out for you.
In any case, good luck and again, be extra careful. Never do this type of work alone, in case something happens unexpectedly.
And as a side note, you may find it next to impossible to find anyone to sell you the motor. Most all HVAC parts houses are wholesale only and will not sell to the general public just to HVAC companys. That's because they are trained to do this stuff with out injury.
Think it over and good luck.
Mar 20, 2009 | Goodman CLJ30AR32 Air Conditioner
Air conditioner motor
Your condenser fan costs less an $100 if you install it yourself. First with the system on and calling for cooling take a screw driver and spin the fan blade. If the fan comes on then it has a bad bearing, if it doesn't it's electrical. With power off remove the access panel and inspect the wiring etc.. Possible run capacitor.
Oct 01, 2008 | Whirlpool Heating & Cooling
Heating & Cooling Logo
163 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
