Question about Maytag MDG8000AWW Gas Dryer
Blown fuse WHere do I find and replace the fuse for this dryer MDG8000AWW
    President:
  • Maytag Master
  • 1,922 Answers
What fuse are you talking about???the only fuse in a dryer would protect the electronics (if your dryer is electronic),otherwise for no heat low heat no operation whatsoever chk fuses/breaker and for power at plug-in for dryer
Posted on Jul 29, 2009
BURNER TURNS ON ONLY FOR A FEW SECONDS THEN SHUTS OFF,
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 01, 2010 | Maytag MDG8000AWW Gas Dryer
Squeeks constantly when in use
REPLACE THE BELT OR USE DOVE HAND SOAP TO LUBE THE BELT BUT USE IT DRY AND ON THE INSIDE OF THE BELT
Nov 12, 2009 | Maytag MDG8000AWW Gas Dryer
Dryer is not getting hot
Check the following to address this issue.
1. No power to the dryer Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Sep 24, 2009 | Kenmore 62602 Electric Dryer
Dryer has no heat
2. Heating element
3. Thermal fuse
Jul 25, 2009 | Maytag MDE2400A Electric Dryer
Dyrer runs no heat cannot locate fuses
2. Heating element
3. Thermal fuse
Jul 20, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Dryer is not heating
Check the following.
2. Heating element
3. Thermal fuse
Jun 25, 2009 | Whirlpool LER5636P Electric Dryer
2. Heating element
3. Thermal fuse
Jun 18, 2009 | Frigidaire Electric Dryer
DRYER NOT GETTING HOT GEQ8858
CHECK THE FOLLOWING--
2. Heating element
3. Thermal fuse
May 31, 2009 | Whirlpool GEQ8858H Dryer
Wont dry
CHECK THE FOLLOWING---
2. Heating element
3. Thermal fuse
May 03, 2009 | Maytag Neptune MDE4000 Electric Dryer
Maytag MDG8000AWW Gas Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
