Question about Toshiba Satellite A25-S2792 Notebook
How do i access the ram on the toshiba a25 laptop. i have searched the underside of laptop and there doesnt appear to be a way to access the ram without taking the entire thing apart
  • 11,896 Answers
Go to control panel, then go to performance and click view computers information and it will tell you processor, ram, frees-space, and more
Posted on Jul 13, 2009
I need more RAM for the A25-3072 Satelite
Maximum capacity of this series is 2gb of DDR400. Also labelled PC-3200. You will have to do this in 1gb sticks over two slots under the keyboard.
I recommend matching sticks, but since it doesn't dual channel even when hyperthreading I've noticed no systemic unreliability in unmatched sticks.
To my knowledge, they didn't make laptop DDR in sizes larger than 1gb. 2gb laptop modules were introduced with DDR2
Nov 09, 2013 | Toshiba Satellite A25-S207 Notebook
Trying to locate the ram
turn laptop upside down and there is a little panal will have 1 or 2 screws in there is the ram
May 06, 2010 | Toshiba Satellite A25-S279 Notebook
How to install 512mb ram for toshiba A25-S279
look on the underside there is a slot for inserting ram in it . but u need to open the back cover to see it and insert in it .
if your product is under warranty i recommend dont do this on your own contact service centre
Apr 05, 2010 | Toshiba Satellite A25-S279 Notebook
Where is the memory located in a toshiba a25 laptop
The access the memory cards you need to do a little dissembly. Remove the battery then remove the securing strip and the keyboard you will find the memory below the keyboard.
Mar 20, 2010 | Toshiba Satellite A25-S207 Notebook
How do i change add ram in a toshiba laptop satellite a25-s279 . I don't see on the bottom where to the ram would be?
It's easy to make the old ram-switch-a-roo if there is no trap-door access on the bottom. expose the top of the keyboard by gently removing the trim cover that's in the way (you may see notches on either end to aide in prying up). Remove the 3 screws - there's a bracket on the center one - take note how it goes. Warning - the keyboard is tethered by a ribbon strip/cable - you'll see it underneath the keyboard - leave it attached - it may be a big hassle to put back the right way! Gently lay the keyboard upside down (you may have to remove the protective cover (one screw) over the ribbon). you'll see the memory on the left. lift the plastic shield back and carefully see how to unseat the stick (there is a clamp/arm on each end) then plug-in and then snap-in the new one - it's notched so it can only go in one way. If you do everything GENTLY and can remember the steps you took so you can put the thing back together, you should be OK. You just saved yourself a nice little pile of cash.
Dec 18, 2009 | Toshiba Satellite A25-S2792 Notebook
Slow
Getting 330 error. In order to fix that, you can run this command at dos prompt > SFC /SCANNOW
It can fix errors at windows XP. Normally there are two memory slots for toshiba satellite. You might be running at 512 or two 256. You can purchase two 512 or i 1g.
Oct 07, 2008 | Toshiba Satellite A25-S207 Notebook
Accessing memory (RAM) to upgrade
First of all, remove the battery
Insert a thin object under the securing strip and lift it up.
Be careful, it may be very tight.
Remove the securing strip.
Carefully work with finger to disengage plastic latches securing the securing strip.
Remove three screws and a metal brace securing the keyboard.
Lift off the keyboard and place it on the palmrest
Now you can access the memory modules.
Jun 12, 2008 | Toshiba Satellite A25-S207 Notebook
RAM Memory Inaccesible
What model is it? You take a peek under the Keyboard??
Jun 06, 2008 | Toshiba Satellite A25-S207 Notebook
Toshiba Satellite A25-S2792 Notebook Logo
115 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
