Question about Brother DCP-7020 All-In-One Laser Printer
Dash drum it keep saying dash drum. Please tell what that mean. I turn it off and on and full the drum. When I put it back it keep saying "dash drum".
  • Brother Master
  • 1,113 Answers
Sound like machine is set to wrong lingo but it will be telling you to replace drum with new then reset counter,
Posted on Nov 16, 2007
I put my sd card in and it says please plug out card what does that mean and now the red light stays on
How to Format MicroSD card of SJ4000 sport camera ...
? 2:22
Oct 11, 2014 - Uploaded by furulevi
How to Format MicroSD card of SJ4000 sport camera. furulevi .... 64 128 GB MICRO SD CARD IN SJCAM ...
What does "please plug out card"mean? - Fixya
Apr 12, 2013 - When camera is turned on it says "please plug out card" What does that mean? ... put in a micro SD card and turned it on and it saying please plug out card what does that ... What does it mean if my camera says "card locked"?
Jazz JDC77 saying please plug card out means - Fixya
Mar 2, 2014 - jazz JDC77 saying please plug card out means Just bought this ... SOURCE: I have a new Jazz DV151 camcorder and the memory card says full ... I bought an sd micro chip for my jazz dv151 camcorder, but everytime i put ..
Dec 21, 2015 | Cameras
There is a lower case I on my dash that's in a white box what does this mean?
cluster warnings are in the operators guide, lost that already?
it says get car serviced, in most cases and explains each.
why not read the manual first. then ask informed questions.?
or post a photo, no camera? 1zillion cell phones have one.
my manual is chock-a-block full of warnings. (hieroglyphics)
if lost , here it is for free, at, (drum roll) JEEP.
even tell what page its on or, show a photo with finger point to warning.
Mar 17, 2015 | 2013 Jeep Grand Cherokee
Lights malfunctioing on John Deere 6910, lights on right hand display flashing. Is this a fuse/relay problem?
Can you tell me which light is flashing,first red one second one in etc.?The first light is the glow plug light and if that is flashing it means the engine has de-rated and you need to find out why.To get the codes that may be stored you can remove the fuse cover and put a 10 amp fuse in the cal location in the fuse panel and the the dash will say diag,when this appears turn the right turn signal on for a sec and the dash will change to all signal again to change the dash until it gets to bcu the turn the hazard lights on for a sec ,now right signal until you get to address 1.Now you hit the hazard switch again right signal and record the numbers in the dash,keep doing this until the image clr appears.Turn off the ignition and remove the fuse.Either contact me with the code numbers or contact your nearest dealership and we will be able to tell you where to look-thanks and good luck!
Dec 26, 2009 | John Deere 6300,6300l,6400,6400l Tractor...
What does it mean when it says Drum near end
It means the drum has nearly reached the end of it's useful life, just a warning before it says it is all used up. If quality is still good you can open the front door and press the menu or options key and tell it it's a new drum and keep printing until the print quality fades.
Oct 26, 2009 | Brother MFC-8870dw Wireless Multifunction...
How do you rest an OKI c3530 image drum
Turn off the printer
Turn the printer on whilst holding down Menu button. (Display says user maintenance.)
Press the menu button three times. (The display will say drum counter reset.)
Press enter key. The system should go back on line, if not press on-line key.
You can just put a new fuse on the drum.
When you insert the drum the machine resets the counter and then blows the fuse. So if the unit is ok and you just wish to run it through another cycle just change the fuse.
This means you cannot just put a full unit in from another machine as it will not reset the counter until you put a new fuse in it as you found out.
This applies to drums transfer belt etc.
Note with regard to refilling the toner, some printers have 2 sections. 1 where you put the fresh toner and an after collection section in the same unit. You must empty the 2nd section if you refill it more than 2 or 3 times
Oct 07, 2009 | OKI C3400n Laser Printer
Problem for print by photo copier
sounds like the charge grid is not set properly in the drum unit..did you et up the drum unit properly and run the new dev and drum set up..if youy are getting black the charge is not working correct as the charge of the drum help to keep the toner from adhering to the drum surface when copying .. I would take the drum chrge unit out again and check it is set in the right way when you put it back on also check the contacts arent put out of line.
Aug 05, 2009 | Kyocera Copystar CS-1820 Black and White...
Canon IR2018 keeps saying waste toner full
...the waste compartment is same unit in the drum unit...if you know how to take out the drum unit then you can see the waste compartment...but be carefull not to damage the drum...couse its will cost you a lot, the price of a drum is high...and if you can change the blade in the drum unit then you can emptying the waste toner...better call for the expert technician...
Jul 08, 2009 | Toshiba e-Studio162D Copier
The drum on my frigidaire dryer will turn when I have a small amount of clothes in the dryer, but the more clothes I put in the dryer the slower it goes until it slows to a complete stop. When I say a...
You probably need to check your dryers drum glides Reach inside and try to turn the drum. It should be VERY easy to turn. If it seems stiff it probbaly needs new glides.
Read MORE about your dryer
May 15, 2009 | Frigidaire GLER341A Electric Dryer
Keeps showing the bag is full
are you getting suction.check the hose at the end and see if there is your brush roller suction will tell it that its full please leave feedback
Mar 20, 2009 | Bissell 3522 PowerForce Bagged Upright...
We have the intellifax 4100. It keeps telling us
Hi Sandy58 this is the fix. all you have to do is: open the front cover (leave it open) and press the clear button then it will ask you NEW DRUM AND YOU ENTER 1 FOR YES and that's it good luck.
any other question please email me,
thank you.
Mar 19, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother DCP-7020 All-In-One Laser Printer Logo
60 people viewed this question
James Cagle
James Cagle
Jim Keysor
