Display not working/functioning
My gateway model ml6732 laptop has had a history of crashes as it loads the desktop. I used to sole the problem temporarily by using the memory diagnostic tool on my operating system disk. Only problem was I couldn't shutdown the computer or it'll crash on startup again. When I thought it was safe a week and a half later, I shut it down. Now when I start it the screen won't show up at all or even light up. I hooked it up to an external monitor but it was blank yet again. Before having shut down my laptop I had installed the full version of Registry Mechanic, assuming my crash problem was because of the registry. It scanned and 'repaired' hundreds of high priority problems while ignoring only two.
Gateway laptop model ML6732 is connected to wireless network nut will not connect to internet
configure your tcp/ip. select this 1.)Obtain an IP address automatically 2.)Obtain DNS server address automatically.
for windows xp click here
for windows 7 click here jump to time 2'52"
another tips click here
Mar 05, 2013 | Computers & Internet
Gateway laptop ml6732 has a startup repair screen and won't boot
Please re install OS .
Please specify what exactly went wrong when u used setup cd to re install
Jan 05, 2013 | Gateway ML6732 Notebook
My Gateway ML6732 says the operating system isn't found. What can I do to reinstall the OS?
buy a copy of Windows OS or you can download Linux that is free like ( Ubuntu, Fedora, Debian, LinuxMint). insert the disk on the computer and just follow instructions. you should have a working os i no time.
Mar 08, 2011 | Gateway ML6732 Notebook
Gateway ML6732 Sound Malfuction
sOUNDS LIKE YOU HAVE DONE SOME SERIOUS DAMAGE TO YOUR LAPTOP
Jan 02, 2010 | HP Pavilion dv9000z Notebook
I can not load an OS,and the hard drive shows 0 space free. How can I fix this. ML6732 Laptop
Either format the hard drive (and lose everything on it) or the drive may have failed and you need a new one
If you found this useful , please rate below
Kind Regards
1234s282
Jul 02, 2009 | Gateway Computers & Internet
I can't get my mouse to work properly on my ML6732. The right button and center pad isn't working properly...
if its on warrenty : take it back to shop not on warrenty: Take it back to shop If u wanne Experiment and try urself: Look under the pad.
Jun 05, 2009 | Gateway ML6732 Notebook
Gateway ML6732 Crashed ...NEED help
Seems you have OS (first guess) problem so if you have recovery disk then insert it in DVD/CD driver and reboot your laptop.
And follow the instructions appeared on sreen and when you reach installation mode choose repair one if you wanna repair OS otherwise choose fresh Installation.
once you are done you should be good to go and if you have Hardware problems then your system will show the bugs on screen during installation period.
oh! if you have any external drives (Thumb drive, Ipod) plugged in then remove before you start above procedure because due to external drives also it happens if you dont have any plugged in external drives then follow the above procedure.
Thank you and post back if any thing changes.
Jan 02, 2009 | Gateway ML6732 Notebook
Computers & Internet Logo
172 people viewed this question
David Payne
David Payne
