Question about Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
The sound does not work on one channel only. The sound works good on all other channels. Why?
  • 11,896 Answers
That channel does not off stereo or digital sound. check your tv to make sure surround sound is on to.
Posted on Jul 13, 2009
Sansui aux-410r amp crackling when switched on followed by high pitched sound and other sound like vinyl played at high volume and stylus being dragged across it .can anyone help please.
This is some kind of componant fault. To find out where determine if the sound is in one channel or both. If in both it could be in the power supply or in something that has both channels common to it. If in just one channel than at least you have the good channel to work with. You can test the bad channel by poking it with an insulated tool. It should make buzzing noises. If it makes buzzing noises in the good channel and is differerent in the bad in anyway you have found something. If the sound also comes and go suspect bad soldering.
Oct 27, 2014 | Audio Players & Recorders
Sound
try to set it default factory mode on the reviver .. or use the user manual to trouble shoot.........
good luck............
May 11, 2008 | Denon AVR-4800 Receiver
First channel doesn't work
You have already done your troubleshooting. If the mike works on your other channels then that particular channel is bogus. And if the pot (volume control) is good then you definitely have a loss of gain/amplification in the channel caused by defective component.
Jan 16, 2014 | PreSonus StudioLive 16.0.2 Digital Mixer
On one channel...PBS we do not get any sound. Sound is ok on other channels and works on the other tv in the house
This television must have the ability to broadcast channels in SAP. Look for an SAP or MTS or AUDIO button on your Sylvania remote. The audio menu might be the place to find this setting as well. You want to remove the SAP and have the tv in either mono or stereo.
Sep 01, 2011 | Sylvania Televison & Video
No sound on some hd channels
If you are only no sound on only some of he digital channels, and the analogue channels are getting sound, and your AV inputs are working you need to check your antenna reception. I hope this helps. Good luck.
Sep 06, 2010 | LG 60PY3D 60 in. Plasma HDTV
I have a four channel amp one side works good but
Switch input co-axel wires. If you still get the same result, you blew that channel on your amp. Repairable
Mar 28, 2010 | Car Audio & Video
TV- some channels don't have any sound, other channels do
RE TUNE UR TV AGAIN AND LET IT FIND ALL THE CHANNELS.......IF PROBLEM PRESISTS CALL PANASONIC SERVICE AND TELL THEM OR PROBLEM U HAVE IM SURE THEY WILL TELL U WHAT TO DO .........OR MAY OFFER U FREE SERVICE......WHAT WILL BE UNDER THE WARREN TIE U HAVE FOR 12 MONTS
Nov 20, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
My amp has lost sound in one channel.I need a circuit diagram.
No you don't really. The good channel will tell you everything about the bad channel as it should be the same. For instance you can measure voltages and compare them and if you prod the good channel and get a loud buzz at various stages. Then you should also get the same results with the bad one. Work backwords from the speaker terminals. Buzz on good Buzz on bad section is working. Buzz on good nothing on bad. Faulty stage. It's not likely to be the power supply as that would affect the other channel.
Apr 04, 2009 | Audio Players & Recorders
Any idea why on my new sharp 32" lcd tv, all cable channels except 57 & 58 (CNN) work fine, but on these channels the sound goes off and on, like there is a short in the sound. all other tvs and cable work...
If you do not have problems with picture and sound on all the other working channels, then the problem you are having with 57 & 58 cannot be a short. The problem you are having is that those channels will not tune in properly through your tuner and this is why you get intermittent sound when they are trying to tune in. The sound tunes in easier than the picture. You said that you have programmed the channels again and I am assuming you are talking about the autoprogramming mode. Try to program those channels individually by deleting them and then readding them. If you cannot do that then you need to take the tv back since it is new or have warranty service look at your tuner and setup your tuner by making adjustments to it directly. Good luck and God bless.
Jan 22, 2009 | Televison & Video
No sound on some channels
Had same problem on Viera 3D Plasma TH-P54VT20A
Select Sound from setup menu and ensure SPDIF Selection is set to PCM (not Auto)
Feb 28, 2008 | ViewSonic NextVision N2010 20 in. LCD...
Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV Logo
99 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
