Question about Karcher K2.26 Electric Power Washer
Karcher 378M Plus Motor idle High and low or start and stop
My unit motor start to idle high and low or start and stop, Motor will stop idleing as soon as I squeeze the trigger but pressure is very low.
I clean filter and nozzle/hose do not seem to be clogged.
SOURCE: gas pressure washer
I have the same problem with a Karcher 2400hh.
Go to: http://www.wmpcs.com/index.php?main_page=page&id=14
they have the best diagrams and answerss that I have found.
Posted on Jul 06, 2009
  • 174 Answers
SOURCE: Karcher G 3000 BH Engine Pumping Problem
This may not be a motor problem. It sounds like your pump is not working properly and the motor is just following the pump. First thing to do is check for leaks in the pump, wand hose, gun etc. It may also be a blown water seal inside the pump.
Posted on Aug 18, 2009
  • 174 Answers
SOURCE: Lack of pressure after releasing the trigger on the wand
Hello awcockerill:
This sounds like the bypass (unloader) valve is sticking. Here is a diagram of your machine's pump. On page 2.4 see part #1. The top of this assembly is a black plastic cover. Remove all of assembly # 1 carefully. Under that is part #8. This is the bypass valve. You need to pull this out, check that the o-rings are not bent, worn or damaged, then lube it good with a VERY VERY good waterproof grease. Re-assemble it and all should be well. The part numbers are on the diagram but where to get them depends on were you live. Karcher web site may give you a number to call. Good luck.
Posted on Aug 25, 2009
  • 5603 Answers
SOURCE: sometimes when I squeeze the trigger I will have high pressure
The bypass valve is sticking.
Posted on Sep 23, 2009
  • 5603 Answers
SOURCE: Hello there.My Karcher pressure washer motor
The valve that admits more water to be compressed is stuck. It is likely the O-Rings on it need replacing. No water to the pump, no pressure!
The motor will stop when pressure is up to the designed pressure.
Posted on Oct 03, 2009
Ryobi 725r carb adjustments
Zama Carb? Turn both low and high meter screws 2 full turns counterclockwise, and idle speed control to maximum. Prime unit and start motor. Run for about ten seconds and then turn idle jet (clockwise) for maximum rpm and then lower idle rpms - readjust idle meter as necessary along with idle screw. Then gun unit at high speed and turn high screw for maximum rpm. Go from idle to max and make sure there is a smooth transition. If not play a tad with the idle mixture screw till that is achieved.
Oct 22, 2015 | Ryobi Garden
Motor only runs on high idle how do I fix it
Check your govenor linkage and action. Your engine has a plastic gear running the govenor inside the crankcase.
Sep 27, 2014 | 5.5 HP GX160 Engine
Just started idling rough, sometimes stalling
Shot in the dark here without knowing the vehicle but it could be an Idle Air Control valve starting to fail. An IAC (idle air control) motor is designed to adjust the engine idle RPM speed by opening and closing an air bypass passage inside the throttle body. The cars computer or PCM (powertrain control module) receives information from various sensors and will output signals to adjust the idle air control motor in or out to adjust engine idle speed by controlling engine idle air. An idle air control motor can fail one of two ways, either the motor short circuits and stops working or the motor will develop high resistance and cause the idle air control motor to react slowly, either failure can cause the engine to stall at idle. When a trouble code scan is performed it sometimes won't always detect a failed or weak idle air control motor. To check the idle air control motor remove the unit, with the wires connected turn the key to the "on" position without starting the engine, the idle air control should move in or out. If the idle air control motor does nothing it has probably failed, replace it with a new unit and recheck system. Note: while the idle air control motor is removed clean (use aerosol carburetor cleaner) the passages the idle air control uses to control idle air speed, also inspect the idle air control for a build-up on the seating (pointed) end and clean as necessary.
Jul 20, 2011 | Mazda B2300 Cars & Trucks
Hello, the problem is varies high and low pressure
try idle screw adjust so motor dosnt labour
Mar 26, 2010 | Karcher Garden
1992 ford f150 xlt- when first started idle jumps from very low to very high repeatedly until warm. then idle is high
try un-plugging the IAC motor,then start it,if it idles low and stays there then replace the IAC motor----if no change then you may have a knock in the engine and the knock sensor is telling the computer to change the timing to compensate for spark knock due to low grade fuel,so it advances the timing back and forth due to too high of rpm then too low and the computer doesnt know how to smoothen it out that fast,but eventually does.The check engine light would usually come on in this case
Jan 23, 2010 | Ford F-150 Cars & Trucks
Idles high to low repeating at cold start
Do you hear any vacumm leaks ??? whats the coolant level at??? check these and then check fuel pressure....
Oct 11, 2009 | 1987 Mitsubishi Passenger
Aug 17, 2009 | Karcher 2500 PSI Pressure Washer
High fast idle at start up.
On most newer cars there is a fast idle motor controlled by the computer that will hold the fast idle till the engine reaches a preset temp in the computer then the engine should drop down to the set idle according to specs for that car. If the oil pressure continues to stay low after the idle goes down you may need to replace the oil pressure sending unit or if worse case the oil pump.
Nov 18, 2008 | 2003 Hyundai Tiburon
Karcher K2.26 Electric Power Washer Logo
150 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
