Question about Frigidaire FRT17G4B Top Freezer Refrigerator
The temperature is set on high in both the refridgeerator and the freezer but it will not freeze things like ice cream its not cold enough and in the fridge things are not as cold as they used to get. Is this a defrost problem or does something need to be drained or what?
  • 77 Answers
Make sure the compressor fan is not rubbing against anything and there is proper air flow to cool the compressor. Remove all dust. Also make sure you don't keep too much food in the freezer to inhibit the circulation of cold air.
Posted on Jul 13, 2009
Freezer in my refrigerator is not freezing some things like ice cream and ice pops solid
Get a freezer dial thermometer (about $5-10 at grocery or box store) and check the temperature, then adjust the freezer (NOT refrigerator) setting dial (usually just inside the top of the cold cut section) a number at a time colder and see how that changes the temperature.
Vegetables and ice cubes freeze hard at about 28-30 degrees F, so freezers are usually set at about 5-10 degrees F, and not above 15 for safety. However, ice cream that is high in cream content generally will be runny to about 25, and soft down to about 0-10, so you may need to set your freezer as low as zero degrees F.
The comment on cleaning the coils is very important - you should do that about yearly, or more often if you have shedding pets. Be gentle with them - you do not want to bend them, as they carry refrigerant fluid, and repairs are expensive. The coils can be under or on the back of the unit, and it is best to not only vacuum them out, but also to blow them out if possible before vacuuming - with compressed air hose if you have it, else with a cleaned-out shop vac on blow setting. Be sure after you blow it out that the fan (usually accessible from the back by removing a cardboard cover after disconnecting power) is not blocked by a clump of lint - it should spin freely. The compressor (roundish tank with wires and tubing coming out of it) should also be blown / brushed off, as lint accumulation makes it run hotter, which reduces freezing capacity.
Also - try putting your ice cream as low in the freezer unit as possible (cold air sinks), and as far back as possible so it does not warm up as much when you open the door. Side-by-sides are bad for this, because all the cold air pours out every time you open the door. You might also try packing something around the ice cream to reduce the effect of opening the door - like bags of frozen vegetables, for instance, or even a wrapped layer of cardboard (although that will also make it take longer to initially freeze).
Jul 06, 2015 | Kenmore Refrigerators
HAVE GE PSS26MSRSS SIDE BY SIDE THAT WILL NOT FREEZE COLD ENOUGH OR MAKE ICE
Hi , you probably need a repairman to check the freon level and test the thermostat
Jun 19, 2015 | GE Refrigerators
What setting do I use to make the freezer freeze food
When you are freezing something, set your freezer on its highest setting. However, if you are going to leave your freezer empty for a long time, you should change the setting to a lower one. Here's a great tip for ice cream: place a tub of ice cream in a ziplock bag before putting it in the freezer; it prevents freezer burn. You know when your ice cream gets so cold, it's hard to scoop out? Doing this stops that, it's keeps the ice cream just soft enough for easy scooping!
Sep 28, 2014 | Maytag 20 cu. ft. Upright Freezer MQU2056B
Upright Freezer not cold enough
Honestly it sounds as if you have a sealed system issue, most likely low on freon.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 13, 2012 | Freezers
check to see if the coilf has a full frost pattern
May 24, 2010 | Haier 13.6 cu. ft. / 385 liter Upright...
Simple Vanilla Ice Cream from recipe booklet is still staying liquidy. Have done everything as instructed. Ingredients are well chilled and ice cream bucket has been in the freezer for two days. Have had...
Your freezer is not cold enough. I had a heck of a time with this machine the first few attempts, when I was in storing it in my main freezer (less cold than the one in my garage). Then i froze the bowl in my garage freezer - it is set to below 32 degrees Farenheit and is designed for long-term storage (gives anything I put in it major freezer burn). When the freezer is set to a low enough temperature, you will find that even 14 minutes is plenty of time to acheive the desired ice cream consistency in the ICE-45 (without having to pre-chill the ingredients).
Other things to check:
Make sure you are using heavy whipping cream and not half-and-half or other substitute.
Make sure that you wait until you are ready to pour the ingredients into the bowl BEFORE taking the bowl out of the freezer.
Aug 18, 2009 | Cuisinart ICE-45 1.5 Quart Ice Cream Maker
Sorbet not freezing
If it is not freezing, I would suspect you didnt use enough salt. Salt melts the ice and makes the water colder. You need lots of ice, the finer crushed the better, and salt. Do not bleed off the cold water, that is where the action is.
Hope this helps.
Aug 03, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
I have a Roper RT21LMXKQ00 Freezer wont freeze
The problem is a defrost problem. The freezer coil has frost on it and thus restricts the cold air from flowing. This affects the refrigerator as it gets its cold air from the freezer. The ice will not make if the temperature is above 12*F and this also is why ice cream is like mush.
Apr 23, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Undependable freezing - sometimes will, sometimes won't!
High room temperatures will throw this unit off BIG TIME. Just to give you an idea how sensitive the freezer bowl is - if you run cold water along the freezer bowl before putting your ingredients in, the COLD water is enough to unfreeze the bowl! Don't remove the freezer bowl from freezer until you are immediately ready to begin mixing - not 5 minutes earlier.
-Tha Mp3 Doctor
Nov 03, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Ice cream has ice crystals in it
Ice crystals are more prevalent in homemade ice cream because it takes longer to freeze the mix. When you can flash-freeze the ice cream to very low temperatures very quickly, there is less time for the molecules to melt and refreeze, which causes crystal formation.
Here are some of the useful tips:
1.) When the ice cream is done, transfer to the coldest part of the freezer as quickly as possible
2.) Pre-freeze the ice cream bowl before using, and pre-freeze the storage container before putting the ice cream in it and into the freezer
3.) Make sure the mix is very cold before using the machine. Maybe put the mix in the freezer for 15 minutes before starting the machine, so that it will finish faster
Hopefully this information helps a lot.
Jul 09, 2007 | Rival 8550-X 5 Quart Ice Cream Maker
Frigidaire FRT17G4B Top Freezer Refrigerator Logo
187 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
