Question about Whitehaus Kitchen Single Handle Faucet with Spray ....
Push button on sprayer cracked. Where can I purchase a sprayer only?
  • 297 Answers
Yes you can,just make sure you take it with you. Not all replacements will fit.you must have the same connector end. they come in a clip style and a screw type. make sure you know what it is you have,one or other before you purchase.
Posted on Jul 15, 2009
Do you know any website relating to paint sprayer reviews?
There are many internet sites on the internet that are providing info associated with paint sprayer reviews. They are especially made for those people who are searching for high quality color sprayer testimonials. Before purchasing it. for more information please visit this website, to understand the product :http://aircompressorjournal.com/top-9-best-paint-sprayer-reviews/
Nov 10, 2016 | Air Tools & Compressors
I have a Titan 640i painter sprayer that is older . Made around 2002 . It will not run . The yellow light flashes but the motor doesn't start. The power source is fine. The pressure is turned up.
If the motor fails to start look for a button (often red) on the motor. This is a reset button for the thermal overload protection most electrical motors of significant horsepower are equipped. Make sure the power is off, push the button to reset, then power on the motor. If the motor still does not start check to see that the mator's shaft turns freely. If not, the mator's armature is frozen due to corrosion or melt down. If the armature turns but the motor still isn't starting, another possibility is that the motor's brushes are too worn or have cracked or fallen apart due to age and/heat. Motor brushes are fairly cheap and normally easy to replace. If you're not a handyman consider taking the motor to an electric motor repair shop to check for continuity and estimate for repair. Hope this helps!
Jun 13, 2016 | Titan 440 Impact Airless Paint Sprayer...
Drips from Grohe pull out sprayer
I would say that there is dirt under the sprayer gasket.or diverter. the gasket may be cracked. easiest solution is to go to a plumbing supplier with the sprayer and replace it.
andrew
Mar 19, 2013 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Washer fluid not spraying out onto windows
when you push the button to spray the window "do you hear the sprayer pump motor"?
If no, your sprayer pump motor could have failed or come diconnected. now if you do hear the sprayer pump kick in then> check your lines "the small rubber hoses that lead to the actual sprayer nossels. make sure the small hoses are not damaged and leaking and not pinched or restricked.. in rare cases the sprayer pump could have failed and still make a sound like its working but not pump out any fluid.. also in some cases BUT RARE you could have a line or filter screen plugged inside the washer resivor.. Good Luck!
Sep 13, 2011 | 2003 Chrysler Voyager
My sprayer is new, but does not keep the pressure, any idea's? It's a 2 gal, pump up type sprayer.
Check under the lid/cover for a rubber gasket. This may have gotten unseated when putting the sprayer top on. It must form a tight seal around the lip of the sprayer top in order to keep the pressure. Alternative: Put water in the sprayer leaving some air on top to build pressure. Put a few drops of dish soap inside and gently stir. Put the cover on, and tilt the sprayer to coat all areas at the top. Start pumping and see where the bubbles come out---there is your leak. If it is near where the sprayer hose enters, and it is a permanent mount, you may have a bad seal. If the sprayer hose unscrews, you may need a new rubber washer inside. If bubbles come out of the wand, or other plastic seams, you may have a crack in the plastic. Depending on the location, you could epoxy over the crack to seal it permanently. Good luck.
Aug 11, 2011 | Roundup 2 Gallon Pro Garden Poly Tank Pump...
Just purchased a PS250 from pvt seller, the instuctions given on top of machine are to 1) push the inlet valve and the push button valve 3 times... where are these valves and buttons located? I do not see...
the inlet valve is located where the siphon hose attaches to the pump.the push button that they are talking about looks like a round part sticking out of the head of the pump.by pushing this buttom you help lift the valve loose so that it will open and close easy.
Jun 07, 2011 | Campbell Hausfeld .28 Gpm Airless Sprayer...
Where on the unit are the inlet valve and the push button valve?
On the front of the pump unit is a large aluminum block, the valves are inside that. The inlet valve is behind the fitting for the suction tube and the push button valve is the only one on the bottom of the block.
Dec 17, 2010 | Campbell Hausfeld Airless Spray Guns &...
Can you tell me how to reinstall the top supply dish rack sprayer please thanks
There is a tab that fits in the center of the sprayer. Place the sprayer on the tub and push in the tab. If it is missing you will need a new sprayer kit.
Thanks, Have a great day!
Dec 11, 2010 | Kenmore Dishwashers
Hi,\r\n
yes you need to reset dishwasher to time fill.turn off the power button wait 10 sec,push and hold the programme and start buttons then turn power back on.hold buttons down until display lights up then release them.press programe button until 4 shows in display,then press start.test dishwasher. F4 is an inlet fault.
Jun 07, 2010 | Asko 24 in. D3350 Dishwasher
Not much pressure on fimco 15 gallon sprayer - purchased new 2.1 gpm motor - it sprays but not a lot comes out - seems not much pressure - Thanks.
Is it possible that the pick-up tube inside the sprayer is clogged up, or the hose it damaged? Maybe dirt in the spray handle/wand?
Oct 26, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Whitehaus Kitchen Single Handle Faucet with Spray .... Logo
73 people viewed this question
Top Whitehaus Plumbing Experts
Donni Steen
Tom Chichester
Are you a Whitehaus Plumbing Expert? Answer questions, earn points and help others
