My Admiral Capacity Plus Clothes Washer Ends Cycle with a Squeal
I moved a little over a year ago, bringing my washer and dryer with me. Since then, my Admiral Capacity Plus Clothes Washer, which worked perfectly since I purchased it new in 2002, ends each cycle with a loud squeal. Also, the inner tub seems to be crooked, leaning a bit to the right. Whether I have straigtened it back up or not, I still hear the squeal at the end of each cycle. I checked to see whether the washer might not be level, but it is level, and I asked a couple of appliance repair guys sent by the home warranty company (to work on other things) what they thought: Both said the squeal was normal. I told one I found that hard to believe since I never had that problem until the move, but he insisted that he was right and that I ''don't know what (I'm) talking about''.
My problem with my washing machine is that it take long to drain out the water.
Posted on Jul 07, 2010
Why is Maytag Centennial 3.2 cu. ft. SuperSize Capacity Plus Top Load Washer shaking during spin cycle
check to make sure it is sitting level on the floor and one leg adjuster hasnt backed in making it shake. But even when you stick cloths in evenly they can bunch up during cycles.
Jan 02, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
Agitator comes off during cycle in my admiral capacity plus washer. How do I fix it?
If the bolt is still on top. it was probably screwed too tight and wore through. then you need a new agitator
Sep 22, 2011 | Admiral 32 cu. ft. Washer
Will not turn on
A dryer can not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 05, 2010 | Dryers
Sometimes does not spin enough to wring out water from clothes.
The spin cycle should be on a timer,and shouldn't be able to change how long it spins.The same timer that controls all the cycles of your washer.Your pump may be trying to go out,and isn't removing the water fast enough.This will keep water in the tub,and the normal spin cycle isn't long enough to let the pump get the job done.Another problem might be a clog in your drain hose.Another problem could be the drain hose is set to high above the pump,and the pump can't push it up that high (shouldn't be a problem if you are using the hose that came with the washer,and not extending it with another hose or something.)
Jun 05, 2009 | Admiral AW22 Top Load Washer
My washer stinks! Literally. How do I take it apart
Smelly Washer Cleaner is the only available ALL NATURAL clothes washer cleaner. Each bottle has 24 treatments! That's UP TO A 1 YEAR SUPPLY @ less than $0.71 per cleaning! It's available at www.smellywasher.com, Ace Hardware, True Value, Handware Hank, Do-It-Best, and many other stores. To compare:
http://vodpod.com/watch/1507525-affresh-washer-cleaner-vs-smelly-washer
Mar 06, 2009 | Maytag Washing Machines
WHIRLPOOL ELECTRIC WASHER STOPPED WORKING MIDWASH BC OF OVERLOAD?
My wife did the same thing,trying to do all the laundry at one time.Even if it says high load compasity it will only handle so much.sounds like you killed your motor.Hope this helped.
For more help go to live chat.
lenwest
Jan 10, 2009 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Load squeal when it in the agitation cycle.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
for detailed help with diagrams and step by step instructions click the link http://www.applianceaid.com/washerspinnoise.html
Dec 29, 2008 | Admiral AW22 Top Load Washer
Admiral washer is doing a lot of vibrating...it is level
Possibly a worn drive belt on the underside of the machine, causing the drum not to get to full speed, clothes will be wetter after sping plus vibrates heavily - replace belt.
Tilt machine back for access to underside, simply pull belt off and replace, tension is automatic on motor.
Oct 26, 2008 | Admiral AW22 Top Load Washer
Need help
This is some basic info I could find on your dryer. I will need you Serial Number in order to determine the year it was produced. Please post back with comments and let me know.
Whirlpool Duet GEW9250P 7.0 Cu. Ft. Super Capacity 8 Cycle Front Load Electric Dryer With AccuDry Sensing System. Dry clothes in the time it takes to wash them. The dryers uses AccelerCare™ technology to work just as fast as the washer (Up to a 9 lb. load), giving you more time to enjoy all the good things you've worked hard to achieve.
AccuDry™ Sensing System - Monitor remaining moisture and automatically stop the cycle when the load is dry, with the AccuDry™ sensor. Reduce overdrying and save time and effort, by not having to return to the dryer to re-check progress.
Senseon™ Drying System - Moisture-sensing strips and temperature sensors inside the dryer drum monitor how fast the load is drying, how hot the air should be and when clothes are dry. The system automatically stops the cycle to help save time and prevent overdrying. Senseon™ technology safely dries clothes faster than it takes to wash them.
Wrinkle Shield™ Plus Feature (120 Minutes) - The Wrinkle Shield™ Plus option automatically tumbles the load without heat to help prevent wrinkles from forming.
Whirlpool brand offers an ergonomic solution for its front-load washers and dryers to help reduce bending, stooping, or arching. Based on your height and laundry room needs, optional 10 in. and 15.5 in. pedestals make loading, unloading, and filling the dispensers easier. The 15.5 in. pedestal doubles as a storage drawer with a convenient sliding shelf to support your laundry basket.
Item Features:
  • Super Capacity Plus - 7.0 Cu. Ft.
  • AccuDry™ Sensor
  • Senseon™ Drying System
  • 8 Automatic Cycles
  • Bulky Items Cycle
  • Adjustable End-of-Cycle Signal
  • Wrinkle Shield™ Plus Feature (120 Min.)
  • 5 Temperature Selections
  • Quiet Dry Plus Noise Reduction
  • Dry Rack
  • Reversible Side-Swing Door
  • Dryer Door Window
  • Reversible Side Swing Door
  • Electronic Controls
  • Front-Mounted Lint Screen
  • Interior Drum Light
  • 4-Way Venting
  • Porcelain SpillGuard™ Top
  • Optional Storage Pedestals Available
  • Stackable Installation with Matching Washer
  • Matches Duet® Washer
Specs:
  • Warranty: 1 Year Parts & Labor
  • Capacity: 7.0 Cu. Ft.
  • Dimensions (HxWxD): 38 in. x 27 in. x 31 1/2 in; Depth with Door Open - 51.5"
  • Construction: Front Access, Reversible Side-Swing Door Style, Powder Coat Drum Material, Dry Rack, Extra Large Front Mount Lint Screen, Power Cord & Venting Accessories, Stackable
  • Controls: Electronic Controls
  • Electrical Requirements: 30 Ampere, 120/240 Volts, 60 Hertz (1/second). AC-ONLY. USE COPPER WIRE ONLY. A FOUR-WIRE OR THREE-WIRE, SINGLE PHASE ELECTRICAL SUPPLY REQUIRED. A TIME-DELAY FUSE OR CIRCUIT BREAKER AND SEPARATE CIRCUIT IS RECOMMENDED.
You can get an owner's manual replacement for your dryer at laundrymanuals.com. I believe there is a membership fee for the website, however. I hope this info helps you.
Nov 23, 2007 | Whirlpool GEW9250 Electric Dryer
Washing Machines Logo
221 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
