Question about Philips 19PFL3403D/27 19 in. LCD TV
TV does not turn on AGAIN. Had it replaced a couple of months ago for the same problem.
    President:
  • 1,077 Answers
It's the #1 plaguing issue with flat panel TV in all brands. Normally, when this happens, the TV goes into " Protection Mode " because of a failing circuit board. Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. Or, it maybe something simple like a blown fuse inside the TV. The most common thing to go out on flat panel TVs is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board. But, I can't say it's 100% the problem because I can'tactually look at the tv over the internet. I can only make guesses with the symptom.
You have a few choices:
1. You can try leaving the TV unplugged for 30 minutes so the TV can reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light flashing codes, circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 13, 2009
2 Suggested Answers
ladywinn
  • 5138 Answers
SOURCE: Have a dlp tv 72.
What is the Model number that is printed on back of TV?
Posted on Jul 24, 2011
TV turning off my itself after a couple minutes.Was told to replace the main board.Replaced the main board and tv played perfect for 1 month.Now it is cutting off my itself again.Whats going on?
Hi Johnny,
Please take out the main board, keep it immersed in mild liquid detergent solution for some hours, rub it thoroughly with a tooth brush, wash it with clean warm water, dry it thoroughly with hair drier and fit it back. Hope it works. It has done the trick for me several times.
Good luck.
Jan 10, 2016 | Dynex Televison & Video
Samsung Plasma won't turn on?
usually caused by the power supply board failing, very common problem.
Dec 10, 2009 | Samsung PS50A466 50 in. Plasma HDTV-Ready
My TN55X81 is showing the same problem.
Replace the IC's with STK 392-110T.
Toshiba has a Service Bulletin on this problem.
Aug 01, 2009 | Toshiba TN61X81 61" Rear Projection...
I turn on the tv and it shuts off after a couple seconds
if you unlpug your tv and plug back is the green ligth blinks for one minute?
let me know so i csn help you
Jul 29, 2009 | Mitsubishi WS-55807 TV
Tv not turning on
I also have this model. A few months ago, when I turned on the tv, it told me my lamp was in need of replacement. just yesterday, my tv did the same as you....the blue light flashed and then the lamp light kept flickering. All I can say is your lamp needs to be replaced.
Mar 19, 2009 | JVC HD-56G657 Television
Panasonic PT 47WX53G
Replace STK392-110 IC's ( both ) with PANASONIC part
# C5AA00000203.........DO NOT use generic IC's !
Terry.
Jul 22, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Toshiba DLP 50HM66
The bulbs for this TV seem to go about every couple years. The price has dropped down a bit. I have found it for 118.00.
Feb 17, 2008 | Toshiba 50HM66 52" Television
Sansung HC-P4752w 52 in. Rear Projection
you require a deflection board replacement the board cost around $150/
Aug 02, 2007 | Samsung HC-P4752W 47" Rear Projection...
Philips 19PFL3403D/27 19 in. LCD TV Logo
654 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
