Question about Craftsman 9-17765 12 Gallon Wet/Dry Vac, 5.0 Peak HP
I need to replace a brush to operate the shop vac. Where can I find it?
  • 21 Answers
True value hardware stores have books to order these parts , piar of brushes are between $3 -$7 ,also most vaccume sweeper shop
Posted on Jul 13, 2009
Does shopvac series 90ln have brushes in motor & how to replace them
A lot of shop vac motors have brushes, due to the motor's power needs. Unplug it (obv) and get to taking off all the covers until it's just you and the motor. On most shop vacs, you shouldn't need to remove the impeller (fan), and it's better just left alone. The brushes are usually just under spring tension.
Jan 28, 2017 | Vacuums
My spin brushes will no work. Have replaced and cleaned screen and brushes are turned on
Is this on a Hoover SpinScrub by chance? If so, those brushes are driven by an air powered turbine. If that turbine isn't turning it may need to be replaced. They can be disassembled and oiled/greased but something like that is better left to a vac shop.
Mar 08, 2016 | Vacuums
How do I access the motor brushes to replace them.
Most vacuum motor brushes are not serviceable by the consumer. without further information, I would take it to a vac shop for service. If you are mechanicaly inclined, take the motor out and then take the motor to a vac shop for service.
Oct 27, 2009 | Vacuums
No power. electric is OK. system will not turn on. Please help
Detach the vac itself from low voltage thin wiring leading to the house. With the vac plugged into power, try the manual switch and then try shorting across the low voltage exterior terminals with a rubber gripped set of pliers.
If you can hear a clicking inside, this is the vac's relay trying to start the motor. If the vac is more than 5 years old , or used more than 2 hours a week, you may need new carbon brushes, or a motor overhaul or replacement depending on wear. Carbon brushes are specific to the motor model # inside the vac, most often an AMTEK Lamb motor.
If you need brushes, the motors comutator should also be inspected for excess,wear, like gap ing between its conatct segments and "apple core" shaped wear
You you have a meter and can test for continuity across the motor leads, do so and post back.
If you don't have a meter, you will likely want to lift the vac off the wall after these checks and take to a repair shop, saving $$$$ for a house call...
Oct 06, 2009 | Broan-NuTone CV353 Central Vacuum
I need replacement carbon brushes for the motor. I haven't been able to find a source.
Try looking for a power tool repair shop, they usually have some brushes and can order more. I have put Hoover brushes in my Shop-Vac.
Look for some that are close to matching,( spring size,spring length, brush length). If the brushes are a little large they can be made smaller by dragging on a flat file. Carefully fit them so they slide into the brushholder nicely.
I have even soldered different ends onto the pigtails, whatever works----I am a pragmatist!
You could also look for an electric motor repair shop in your area- they have suppliers.
Apr 27, 2009 | Hoover Portapower C2094 Bagged Canister...
Kenmore vac producing burning odor
It sounds like you have bad carbon brushes on the motor. Get replacement brushes from a local vac shop, and take the unit apart. On each side of the motor their is a retangular piece of plastic with what looks like magnets in them. In most cases they are simply held by 2 screws. Replace these brushes and reasemble the unit. If the problem persists you have burned out the comutator on the motor and the whole thing must be replaced.
Apr 15, 2009 | Kenmore 22085 Bagged Canister Vacuum
Moto Brushes Problem... Who could help?
where can i fine moter brushes for my ridgid 5.25 hp 16 gal. wet dry vac.
Oct 02, 2008 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Shop Vac just stopped
If you remove the motor, you will see that the wires that go from the switch to the brushes. On one side there is one wire connected directly to the brush. On the other side the wire goes to a plastic plug with a second wire going to the brush. This is probably where the problem is. This is a fusible link and it has most likely melted creating an open in the circuit. I put a piece of solder where the link was and the motor ran BUT the brushed arced like a sparkler. Upon further examination the brushes were crumbling apart. I have been unable to find replacement brushes.
This machine has a five year warranty. I called Shop Vac Customer Service 1-888-822-4644 and they sent me a new motor.
I had a Shop Vac QL50EIC which had exactly the same problem but the warranty was expired so that I had to buy another motor for about $50.
Mar 08, 2008 | Shop Vac 285-00-10 Back Pack Vac Wearable...
My shop vac won't turn back on after emptying
I'm afraid you'll need to take it apart. the switch is mounted in a plastic holder in the top. While you got it apart and without it plugged in, check to see that both brushes are touching the commutator. there should be sufficient spring tension to hold the brushes against the spinning part [commutator] if even one brush isn't making contact it won't spin.
Sep 10, 2007 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Craftsman 9-17765 12 Gallon Wet/Dry Vac, 5.0 Peak HP Logo
270 people viewed this question
Top Craftsman Vacuums Experts
downhille
Vernon Taylor
Are you a Craftsman Vacuum Expert? Answer questions, earn points and help others
