When i boot my computer.
on the window loading screan i see a massage
windowsystem32configsystem
file is crupted you repaire with xp sp 2 CD
and i have that CD but how i repair that one file
tell me the way.
Insert your Windows XP install Disk and reboot
when it asks if you want to repair or install windows pick INSTALL. it will then search for previous installations and find yours.
At this point you press R for repair, it will reair your entire installation of windows, leaving your prgrams and files intact.
Be careful though, as the wrong choice could wipe your drive, although you are given many dire warnings by the installer before you do this, so if you read and pay attention you should be safe.
If my solution was helpful please vote for me!
Im not sure which file you are referring to but you could just a repair of the installation
this is fot the master boot record
if there are any other files , settings or programs during the repair process options for these should be available
Insert your Windows XP installation CD or recovery disc, and restart the computer.
Instead of attempting to boot Windows as it normally would, the computer will give you an option to boot from the CD.
Press a key when prompted, then wait for the setup program to load.
Press the "R" key on the "Welcome to Setup" screen.
This will cause the CD to launch the Recovery Console instead of attempting to install Windows XP on your computer.
If you have an administrator password on your copy of XP, then you will need to enter it in order to log in to the Recovery Console.
Choose the installation of Windows XP that you want to repair (generally the only option). Wait for the command prompt to appear, then enter "fixmbr." Press "y" when prompted to let the FixMBR utility overwrite the corrupted bootloader with a new copy.
Remove your XP disc or recovery disc, then type "exit" into the command prompt.
The exit command should cause the computer to reboot, allowing the computer to load the new bootloader file and then continue Windows XP startup as normal.
Hope this helps
when i boot my computer.
window\system32\config\system
tell me the way.
windowssystem32configsystem file is crupt
