I have a RICOH 210 just newly buied
Printer's both the Red continuously on while starting the Printer can any one help me out to get rid this problem.
Sir Plz Update To RICOH SP 211 Printer Paper Load
Not Working...
RICOH SP 211 Printer 1st LED & 3rd LED Light
One Time On...
Plz Sir RICOH SP 211 Printer Repairing Solution...
I had the same problem, but solved it.
You have to connect your printer SP210 to your computer.
Search (in Windows) "Smart Organising Monitor Status"
Select Printer (new dialog box)
Click OK (see the error code SC545)
Click on User Tools
Printer Configuration
(Access Code is Admin074)
Find Fuser SC Reset under Maintanance
Click Ok
Close
Restart your printer
Your problem is solved now
how to download smart organizing monitor status
Normally it installs along with the printer driver. If not, it is available in google....
Little sensor switch on tray. Tape it or remove it or replace it
Click on User Tools
Click Ok
Close
Make sure settings are on for tray feed.
SOURCE: Canon MF3240 printer error message.........
I think I solved my printer problem: Chang the paper size to LTR in the printer panel. then go to compter printer setup and choose printing preferences and choose page setup and chang the paper size to Letter (LTR) also. hope this is helpful.
SOURCE: paper tray is full and the paper light keeps flashing.
First check the machine for paper jams. If not, remove the paper from the paper tray and reinstall it. Then try to print from the MP tray.If this works, check paper size settings on the printer driver, or the small black arm which hangs down next to the paper pick up roller, and is the paper sensor.
SOURCE: I want to print a photo using the photo paper
I had to adjust the advanced print settings on my computer.
SOURCE: Red "Paper" light stays on; printer will not print.
Paper light flashing could mean several things on this machine.
There
could be a paper jam in the machine. Open the front cover remove the
drum and toner and look in the machine. You can also check in between the drum and toner by removing the toner from the drum. Open the back cover and look
for a Jam as well.
Try putting a piece of paper in the manual
feed tray which is right above the paper tray, sometimes on certain
documents the margins are too big and asks to go into the manual feed
slot.
SOURCE: Tray which printer prints from.
Just had this problem and stumbled upon how to fix it. Check the guides in your tray 2. Our back guide was slightly off of the proper spot for letter size paper. This was causing the printer to think the tray had a custom size of paper in it. Your document is probably trying to print on letter size paper and when it doesn't think the paper is in there it switches to tray 1.
