Question about HP PSC 2210 All-In-One InkJet Printer
How do I replace the printer cartridge belt (2mm blk rubber) that the print heads travel on?
  • Duke Bells May 11, 2010
    It will be better if you have this done practically in your presence and once this done you will be able to carry out the job
    Habit-Forming:
  • 121 Answers
Hope to hear from you soon
Posted on Jul 13, 2009
Why wont my printer print in blk?
take the black cart. out and dab on a wet paper towel, unplug printer and use q tip to clean the print head where the cartridge goes with alcohol, if that doesnt work you have a bad cartridge
Nov 09, 2015 | Office Equipment & Supplies
Unsupported ink cartridge after power outage
(1) Open the printer and wait for the carriage to slide over. If for some reason it does not follow these instructions:
(a) Unplug the printer
(b) Manually slide the carriage over until you can get the ink cartridges out.
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water or a mix of hot water and isopropyl alcohol to thoroughly clean the print head.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
If that does not work then you have one of two possibilities:
(1) One of the ink cartridges is defective and causing the error
(2) If it's definitely not that, then the print head will need to be replaced.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Canon Printer Support
Mar 18, 2014 | Canon PIXMA Office Equipment & Supplies
WHAT IS THE CARRIAGE CARTRIDGE
There are two different types of carriage units that you may be referring to depending upon the model printer you have. Older types of photo printers had two distinct carriages.
1. Carriage referees to equipment that travel left to right in your printer.
2. One is for the print heads that receive ink from your print cartridges and dispenses it to the paper that you are using.
3. The print head carriage that travels back and forth to accept replacement ink cartridges. Most of the time it is tucked to one side or the other and only travels when the printer is opened in a specific way to expose it for ink replacements.
In newer systems the print heads are built into the Ink cartridge, each color has it's own print head.
So in answer to your question the carriage cartridge is more than likely the container that you put your ink cartridge into. Unless you have an older printer and then it would or could be the carriage for either the print head or the ink. They some times need to be replaced. I had to replace that cartridge in an old HP2500 for as long as we had the printer. (4 years). Great machine high maintenance.
Aug 23, 2012 | HP Photosmart C7280 Printer
Won't print black, prints every other colour ok
1. try to cleaning head
2. remove the black cartridge only, (if it doesn,t changed after you cleaned head)
3. provide some warm/hot water on a bowl or plate.
4. enter the HEAD of black cartridge in to hot water. soak with depth about 2mm up to 5mm. while you see the ink is come out....
5. after the black ink has come out. pat dry with a paper towels/tissue.
6. replace the cartridge in to printer.
7. cleaning head again and print test page
good luck....
Jun 19, 2011 | Canon Pixma MP500 All-In-One InkJet...
My eson xs 200 printer problem is not print black ink ol catush is new
perhaps this is can be help you....
good luck
Jun 19, 2011 | Office Equipment & Supplies
Canon MX300 printer--I replaced the black ink cartridge, reset according to instructions. Printer receives print jobs, but prints blank. Cleaned and deep cleaned heads. Test page prints blank for both...
Try this method to get the ink flowing:
  1. Simply fill a saucer with approx 2mm of just boiled water
  2. Place the print head in the saucer with the head in the water.
  3. Leave the head in the water for approx 2 - 5 Mins
  4. The Heat will assist in dissolving any blockages and help the ink to flow with out using any chemicals.
If it is a compatible cartridge you have used then it is possible to get a failure. Most are re-manufactured and are not 100% Reliable.
Also make sure the contacts on the inside of the printer are clean and all there. sometimes they can be damaged by removing and replacing cartridges. these can be cleaned with alcohol wipes.
I hope this helps Regards GM
Apr 23, 2011 | Canon MX300 Office All-In-One Printer
My Canon MP240 suddenly began printing streaky lines at regular intervals on the page. In between the print is good. I have done all maintenance functions without success. I think perhaps the roller may be...
Try Pulling the print head out and cleaning it manually
  1. First remove the cartridge
  2. lift the orange or green lever on the side of the cartridge holder and pull the print head out.
  3. Fill a saucer with boiling water, about 2mm deep
  4. Place the head in the boiling water and leave for about 2 mins. Dry before replacing in printer
  5. While the head is out have a look in the printer for any excess ink on the rollers or where the cartridge head "rests". Clean with tissue paper if needed.
  6. Re-assemble the printer, replace the head and cartridges and test.
I hope this helps
Regards GM
Apr 10, 2011 | Canon PIXMA MP240 All-In-One InkJet...
I have a mfc-665cw and dosn't print blk . i replaced the cartridge twice
Please reset your printer head or clean.If you are not fix this problem replace the printer head.
Jan 07, 2010 | Brother Multi-Function Center MFC-240C...
HP PSC 2210 All-In-One InkJet Printer Logo
91 people viewed this question
Seeker5211
Seeker5211
