Turn tv on plays for afew mins pop then it turns off thne back on.
  • 11,896 Answers
Bad capacitor on the power supply that will need to be tested and replaced
Posted on Jul 13, 2009
The TV menu options keep popping up aprox. 15 mins after turning the TV on.
Do a reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jul 09, 2017 | Televison & Video
RCA Modal 27V513T was playing with menu and tv turned
unplug it from the outlet,wait 2 min. then plug back in to see if it reset. if not suspect it to be in the power circuit of unit
Feb 14, 2010 | Televison & Video
3232 polaroid tv,makes popping noise when i turn it on.
this sounds like the problem most LCD tv's get with swelled up capacitors in the power supply board. look for circular cylinder shaped parts rapped in plastic with writting on the sides, and metal tops, if the top is rounded over, not flat, it is bad. replace them.
Jun 25, 2009 | Polaroid FLM-3232 Television
My ps3 keeps freezing?
The only thing I can recommend doing is backing up your info and then trying to get to the restore option under the ps3 before the green squares pop up, if you are not able then contact Sony before your lose your warranty.
Dec 22, 2008 | Sony Playstation 3 (PS3) Console
Tv wont turn on after fixing convergence problem
Check the pins with a strong magnifying glass to make sure they are solderd correctly with none of the pins bridged with solder, then recheck all the wire connections to make certain they are correctly hooked up.
Apr 16, 2008 | Samsung HC-P4752W 47" Rear Projection...
TruTech 19" LCD TV+DVD
I have a sansui 19" LCD TV+DVD
I had to attempt multiple times turning the TV on to get a picture. The sound was fine. This kept happening when I would go to turn on the set the TV kept playing fine with picture & sound but after the 2nd attemts I turned it off & then tried to turn it back on which took multiple attempts, it kept playing for a few minutes then the picture went out but the sound was still there.
The set is not yet 2 years old.
Mar 13, 2008 | TruTech PLV1615T 15 in. LCD Television
Gateway Plasma 42" TV
my 5 yr. old 50 inch plasma hd that i paid almost $7000 for started flashing for afew sec. when first turned on.progresivly got worse,flashed for about 30 min. then ok until turned off.after about a month power light comes on fans start then trips off. gateway phone 888 737 6949 wants $250 for power supply $330 for video?board $600 plus for other boards no guarantees.i fixed mine by spending $1000 for a new vizio 50 inch plasma hd.if anyone wants a free dead gateway email me,
archie
Mar 02, 2008 | Gateway GTW-P42M303 42 in. Plasma...
Philips model ptv915 model # 60P8341a
  • sound  off & on is dye to loose contact in sound section
  •  plz check
  • speaker wire or connector loose.
  • speaker defective.
  • loose contact or print loose in sound section.
  • supply to sound section.
  • sound output ic or print loose.
  • hopr this will help
  • good luck.
Oct 19, 2007 | Philips Magnavox 27MS343S 27" TV
3d effect
Hello, please replace convergence output IC`s and R7048 (2,2R). If you need more info please contact me at LIVE Expert Assistance. Best regards, Arpi
Jul 01, 2007 | Panasonic PT-47WX49 47" Rear Projection...
TV turns on for about 10-15 min then turns off
Sounds like a tuner section problem. When you are playing a DVD. You are only using the audio video circuit of the TV. Something like a monitor. But when you go back to TV mode... You are now in the tv tuner circuit. And your problem lays there. I had a mouse **** on my tuner section of my tv and it caused the same problem. Yes mice do ****...
Aug 18, 2006 | Panasonic PT-47WX53 47" Rear Projection...
Open Questions:
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
Electro Med Services...
