Question about HP Compaq Presario V2000 Notebook
Laptop mouse I'm using hp laptop. The mouse pointer speed is very slow. I know to increase the speed of the physical mouse,but how to increase the speed of the inbuilt mouse(regular laptop mosue). Please help me .....
  • 63 Answers
Re: laptop mouse
Go to Start --> Control Panel --> Mouse.
Click on the Pointer Options tab and adjust the slider for the pointer speed.
Posted on Nov 16, 2007
0 characters
3 Points
What is causing my computer to act like a Robot, or like a Strobe light?
Have you tried changing the mouse speed and sensitivity?
Jun 28, 2015 | HP Pavilion PC Laptops
Dell PC Laptops latitude E6400 Touch pad slow
You can change the responsiveness of the pointer by going to Control Panel > Mouse > Pointer Options Tap > then increase the pointer speed.
Feb 14, 2013 | PC Laptops
The cursor jumps around on my ASUS K501J notebook.
Step 1
1. Open Mouse by clicking the Start button, clicking Control Panel, clicking Hardware, and then clicking Mouse.
2. Click the Pointer Options tab, and then do any of the following:
To change the speed at which the mouse pointer moves, move the Select a pointer speed slider towards Slow or Fast.
• To make the pointer work more accurately when you're moving the mouse slowly, select the Enhance pointer precision check box.
To speed the process of selecting a choice when a dialog box appears, select the automatically move pointer to the default button in a dialog box check box.
To make the pointer easier to find when you move it, select the Display pointer trails check box, and then move the slider towards Short or Long to decrease or increase the length of the pointer trail.
To ensure that the pointer doesn't block your view of the text you're typing, select the Hide pointer while typing check box.
To find a misplaced pointer by pressing the CTRL key, select the Show location of pointer when I press the CTRL key check box.
Change mouse settings
Step 2
If you are using touchpad, try reducing the Touchpad sensitivity and check
1. Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop. From that screen, choose "Mouse Pointers."
2. Select the "
Buttons" tab at the top of the dialog box that opens. This shows the type of touchpad device installed on your laptop.
3. Set the touchpad for right or left-handed use from this dialog box. You can adjust the double click speed of your computer as well. When you finish making any changes, click "
4. Pick the "
Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings."
5. Read the information provided in the next dialog box. It gives you options for tapping your
touchpad, using the buttons, scrolling, pointer motion and sensitivity.
6. Make any changes you want from the various topics. When you make a change, click "
Apply." Click "OK" when you finish making all your changes.
7. Do some work on your computer for a while, If the touchpad is still too sensitive, return to the "Mouse" menu and continue to adjust the settings until you get them just the way you want them.
Step 3
If the issue persists try to perform a clean boot and check whether the issue is still persists.
Follow the steps mentioned in the article given below.
How to configure Windows Vista to start in a "clean boot":
Note:Once the troubleshooting is over, reset the computer to start as usual.
Also I would suggest you to keep in touch with mouse manufacturer
Oct 08, 2012 | ASUS K50IJ Notebook
I have a TOSHIBA NB100.The mouse pad is too sensitive .I can even move the cursor hovering my finger above it without touching the pad .I thinlk it causes words and letters to come out as a jumble. Is...
control panel----Mouse----Should bring you to a screen with several tabs at the top-----pointer options tab---Select a pointer speed this should slow down the mouse movement----then go to the first tab (touchpad) and you can change the touchpad sensitivity. Hope this helps
Jan 07, 2011 | PC Laptops
I have a Dell studio laptop. Recently, within the
1. In order to fix this, you go to control panel > mouse
the last tab is called "Device Settings" click it and make sure you have "static tray icon in taskbar" selected.
(You can always remove this later.) Apply the changes and click the red coloured icon in your task bar. An option will be available called "Tap to click." Clicking it will enable you to tap with your mouse pad instead of the keys! Hope this helps you out, I know it helped my friend.
In the Control Panel open Accessibility Options Icon and click Mouse Tab and than Setting.
To move the mouse pointer by using MouseKeys
If you have not already done so, turn on MouseKeys.
To turn on MouseKeys, open Accessibility Options, click the Mouse tab, and then select the Use MouseKeys check box. Use the buttons on the numeric keypad to move the mouse pointer. If MouseKeys doesn't function, press NUM LOCK, and then try MouseKeys again.
To move the pointer horizontally or vertically, press the arrow keys on your numeric keypad.
To move the pointer diagonally, press HOME, END, PAGE UP, or PAGE DOWN on your numeric keypad.
Notes To open Accessibility Options, click Start, click Control Panel, and then double-click Accessibility Options.
To specify whether NUM LOCK must be on or off for MouseKeys to function, on the Mouse tab, click Settings, and then for Use MouseKeys when NumLock is, click On or Off.
To change the pointer speed and acceleration when using MouseKeys, on the Mouse tab, click Settings, and then move the sliders to adjust the pointer speed and acceleration.
To temporarily increase or decrease the pointer speed, on the Mouse tab, click Settings, and then select the Hold down Ctrl to speed up and Shift to slow down check box.
Jul 27, 2010 | Dell Studio 1737 Laptop
I want to adjust the sensitivity of my touch pad, but I cannot find any software that allows me to do so. The only pointer software and driver hardware apparent in control panel is for a mouse.
those mouse options, speed, buttons, tapping to click - should still apply to the touch pad - see if Have a look at a TAB called Pointer Options - that will enable you to slow and speed up the touch pad response
Apr 22, 2010 | HP Pavilion dv2742se Notebook
I recently had my hard drive reformated and a
You can change the mouse seetngs by going into
Start-> Control Panel-> Mouse
Click on that and you will have a mouse properties dialog box.
In pointer options tab select the pointer speed you desire.
This will help restore the pointer to its normal speed
Jul 12, 2009 | HP Pavilion dv4000 Notebook
Lapptop touch pad not responsive
hii srm-mom ....
see jst fallow wat i m sayin....
go to start option>control panel>printer n other hardware>mouse
here u can set urs mouse speed n urs mouse pointer....
if u r not able to see ny mouse pointer choose diffrent pointer..
if irs mouse speed is slow u can increase it also...
try dis tell me.....
dis settting for windows xp nly....
if ur usin vista same as it but sm diffrent..
Jun 22, 2008 | Toshiba Satellite A135-S4527 Notebook
Mouse is too fast and picks before I get to object slowing it down
Go Start > Control Panel
Choose Mouse and click on it
A menu will appear go to "Pointer Options" choose the speed of pointer. If issue persist please post for further troubleshooting. When Issue resolved please rate accordingly.
Good Luck
Jun 06, 2008 | Toshiba Satellite A105 Notebook
Lenovo R52 doesn't remember new mouse pointer speed
Are you trying to configure any external mouse attached or the track ball / touchpad?
Mar 16, 2007 | IBM ThinkPad T42 Notebook
HP Compaq Presario V2000 Notebook Logo
129 people viewed this question
Top HP PC Laptops Experts
Brian Sullivan
Brian Sullivan
Michael Thomas
Michael Thomas
Are you a HP PC Laptop Expert? Answer questions, earn points and help others
