Question about Kitchen Appliances - Others
I lent my portable cooler to a guy ,and when he returned it it didn't work , and he told me that he had taken it apart to clean it and dosn't know how or where to place each plug on the circuit board.( KOOLATRON P34 ) portable cooler.please help? miketo@rogers.com
    Scholar:
  • 113 Answers
Hiya Mike
Solution 1 - Dont lend cooler :)
(just kidding)
Not familiar with it but would be very surprised if the plugs are interchangeable. I should be power in and the other for the thermos. Check and see visually and if they can be mixed up and dont get a response, could try sending a pic of the PC and see if go any further.
Best of luck. Ganx
Posted on Jul 13, 2009
Ultracool Portable Evaporative Cooler CP35--says "no water" but water has been added---how to get it to work.
I have/had the same problem with mine and I know it to be the float as I took it apart and I can get it to work if I remove the circuit, but then if it runs dry and I am not around, I run the risk of burning out the bump. I can't find the replacement part; anyone have a clue where to get parts?
May 29, 2014 | Champion International Champion Cooler...
The bike is sitting for 4 years, I have some one to check it out. The bike did start but it would shut off if gas is not idle. The guy told me to replace the fuel pump which I did. Now still doesn't want...
After 4 years you are virtually guaranteed the carbs will need to be taken apart and cleaned. Gas breaks down into a brown varnish type material. This varnish needs to be dissolved by disassembly and soaking.
The fuel system in general will be suspect and needs a thorough cleaning from tank to carbs. No way around this if the bike has been down for that long.
Take care.
Dec 07, 2010 | 1998 Honda CBR 600 F(3)W
John Deere 310 A Hydralic problems
Jd 310 A, boom down to dig then back off stick alittle and circut loses power.
May 08, 2010 | John Deere 420,1020,2010,2020,2510,2520...
How could i clean the air cooler, i used have a bad smell when i switch on the cooler fan
What you do is remove the hog hair and replace it. Then clean out the pond. Then remove the blower and take it apart, oil the motor and wash the wheel.
May 04, 2010 | Cfm Kenstar Turbocool Major Portable Swamp...
The self timer lever is stuck in the activated position of my Yashica-D. Is there an easy solution?
If the shutter release does not activate your timer and release the shutter, it probly needs taken apart by a repair guy. They can free the timer, clean out the old dried up lubricant, put in fresh lubricant, adjust everything and return it to you...working.
lightspiritphotography.com
Oct 27, 2009 | Photography
The tiller bogs down, loss of power.
I have had same problem. First time, I sent it out for fixing. They told me exhaust was clogged. They clean and it ran great. From then on, I started cleaning exhaust and intake myself. Also found manual online, which helped a lot. I've since then found out that the Mantis motors are similar (or a branch off) of Echo. So many parts are similar to their gas blower pack. Home Depot had a kit that had spark plug, air filter, and fuel filter in it all for ~$12. Had to tear off rubber from around air filter, but other than that had it running great in no time. I've also learned since finding the manual online, that the gear box should be checked/lubed each year, and also how to reseat motor on drive shaft, if slips off.
Good luck
Dan
Mar 09, 2009 | Mantis Tiller
Automatic transmission lines
Hi!
The two lines from the transmission is the cooler lines,one is the inlet and the other the outlet.
If the rad and cooler stand vertically then the out line from the transmisson must connected to the top so that the transmission fluid can be cooled and returned to the transmission.
Jul 06, 2008 | 1983 Chevrolet K1500
How to clean pump
If you can turn the impellar on the pump with your hand and it runs freely, then the pump is ok. You should maybe look at the hose that leads to the drain pump from the drum, or the drain hose that goes from the pump to the sink/tub. It may be clogged with lint. Remove the drain hose from the spigot under the sink/tub and check the spigot. It too may be clogged. It is not possible to get into the pump. It is a sealed unit, unless you are able to unscrew the impellar from the motor shaft to check underneath it.
Oct 12, 2007 | GE Energy Star WCVH6260F Front Load Washer
Kitchen Appliances - Others Logo
113 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
