Question about ViewSonic PJ503D Projector Lamp
Viewsonic PJ503d won't turn on 65-70 percent of the time....
We replaced the bulb in our Viewsonic PJ503d. The new bulb worked fine for approx. 20 minutes, then shut off. After rechecking the bulb install and trying to turn on again, no luck. Put the original bulb back in and it worked again. Got a free replacement blub that again, worked for 20 min. and now it only turns on when it wants to. It will go through a whole warm up cycle and then just power off again. I also hear a noise that almost sounds like something is "sparking" inside but I'm assuming it's the ballast trying to ignite the bulb. Any insight?? The bulb will ignite 30/100 attempts.
SOURCE: my viewsonic pj400 projector switches itself off
hello
i have the same problem, a clear image, the the projector shuts down, turn the fan on, and "lamp" blinks.
i returned my projector to viewsonic service center, they told me to change the lamp.
the problem is that a lamp is very expensive!
HudgeFR
Posted on Aug 05, 2009
  • 286 Answers
SOURCE: My ViewsonicVP930b Monitor Suddenly Turns Off
This is a classic VP930 problem.
It is caused by bad capacitors in the power supply circuit.
Open the monitor, and look at the power board. There are six capacitors. Replace the 220uF @ 25V and the 1000uF @ 16V capacitors. I would recommend replacing them with 35V and 25V capacitors respectively.
If the serial number on your monitor starts with Q8H you could also have a bad IC on the main board. Q8 on the main board is an FET in an IC package. If this problem persists solder a wire from the right side to the left side. There is one pin that turns the IC on and off. All the other pins (per side) are soldered together. Do not solder the pin on the left side that is by itself. Just leave it. Solder ALL the other pins on the left to ALL the other pins on the right.
Remember, do this ONLY if the problem persists after replacing the capacitors AND if your serial number starts with Q8H.
Posted on Sep 15, 2009
SOURCE: Viewsonic N3000w LCD TV randomly shuts off...
hi,guys with shutting down viewsonic t.vs.
As you power up your t.v continously press input button on your tv
until it powers on.Sometimes last all evening,someyimes for 5 minutes.
your welcome
Posted on Dec 01, 2009
  • 6 Answers
SOURCE: Viewsonic PJ550 lamp
Problem 1) The projector should put out a burst of 7000-15000 volts to start the lamp, and then immediately drop down to 60-100 vlts to keep the lamp lit. It sounds like the bulb blowing took out your ballast, or the ballast going out took the bulb (uncontrolled current = overheated bulb = boom)
Problem 2) Thats not a problem at all. HID lighting uses an arc to create light, just like welding creates light. Since it uses an arc, and not the heating of metal, there is no filament to test the resistance of. All the bulb is, is a special mixture of gasses and two very durable electrodes, with a gap in between.
Posted on Dec 02, 2009
SOURCE: i have a viewsonic pj402d projector. put in the
Your Heat Sensor is probably faulty, try a replacement.
Posted on Feb 03, 2010
How do I open up?
NOPE U NEED TO REPLACE COLOR WHEEL
Oct 07, 2015 | ViewSonic PJD5134 DLP Projector
My viewsonic 3d projector won't turn...but it has
You should replace the lamp it is already damage, when you replace the lamp do not forget to reset the lamp hour meter.
Aug 22, 2011 | ViewSonic Televison & Video
My PJ503D shuts down maybe a minute or two after turning it on, what causes this? is this the lamp? anyway, the lamp time usage has already reached 937hours,
hi mayn,
i have some proposal for you reference,
1-- does it thermal overload protetion?? so check the van is working or not,
2-- check the color wheel is ok or not? clean it and check the 8pin chip loose contact or not?
3-- the last, consider the lamp, but it just worked less than 1000h, it should have longer life,
hope this is helpful for you,
Jacky,
you can freely contact me for further help, by mail, wanmingjun@gmail.com
Mar 15, 2011 | ViewSonic PJ503D Projector Lamp
How do i reset the lamp hours? i just bought a new bulb and put it in
Press and hold the UP button on the projector for 5 seconds, this will display the Total Used Lamp Time. Press AUTO on the projector to reset the timer to 0. Wait for roughly 5 seconds for the On Screen Display to disappear.
Feb 28, 2011 | ViewSonic PJ503D Projector Lamp
How do i reset the lamp hours on viewsonic pj503d i cant afford another bulb right now and i know theres a way to reset it just trying to buy some time untill i can afford one thanks alot
Though you can reset timer in the info menu it is unwise to do so as the bulbs can explode if they go past there usage time and can cause damage to projector.
Have a look on ebay there are a lot of bulbs on there maybe you can find a cheap one.
Please dont forget to vote this answer was helpful
Many thanks
Feb 17, 2011 | ViewSonic PJ503D Projector Lamp
Set is an LG DLP model RU 52SZ51D. Set sometimes needs to power cycle 20 or more times to fire up. Other times 1 or 2. The red led turns to amber and flashes approx 55 times and then turns to red and...
I need to know titles of lights that blinks on tv while it trying to power up. There are Power, Lamp and Temp lights, let me know what light blinks, this will help me to diagnose the problem as I hate to guess like try this and try that.
Thanks.
Aug 26, 2010 | Televison & Video
Lamp timer reset on my veiwsonic pj503d
hold the up button ( on the actual projector not the remote ) for 5 sec and then press auto
Sep 07, 2008 | ViewSonic PJ551 Multimedia Projector
ViewSonic PJ503D Projector Lamp Logo
396 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
