Question about Dell Latitude D510 Notebook
Will not run on ac adapt. only battery and will not charge
  • 453 Answers
Check by connecting the adapter to another plug point.
Please check the light on the AC adapter. If there is no light then it is better to replace the AC adapter.
Check the laptop with another AC adapter of the same type. if the laptop works fine with the other AC adapter then replace the adapter
If the light on the AC adapter is on visit the manufacturer's website and try to update the BIOS. If this does not work. check by juggling the connector at the laptop's end. If the laptop charges intermittently or if there is no signs of charging, it is advisable to contact the manufacturer for having the motherboard checked.
Posted on Jul 13, 2009
Pyrhyc
  • 2028 Answers
SOURCE: Dell Inspirion 1526 Laptop Battery is not charging
Sound like the battery. Take the battery out and there should be a power meter on it, press it, if there are three lights that flash, the battery is shot. Not all batteries will flash if they are worn out, but they are supposed to. Try a new battery, I believe this will coorect the issue.
Posted on Jun 21, 2008
  • 5 Answers
SOURCE: IBM T30 - power issues
You might try cleaning the battery compartment. Makeing sure there are no damaged pins. Often times even a single messed up pin will cause this. Also this is a very good indication of adaptor failure. If you haven't allready I suggest getting another ac adapter specific to you machine. Even a substitute will casue the same issue you are now experianceing.
Posted on Jul 11, 2008
  • 1151 Answers
SOURCE: The AC Adapter makes a beeping noise and doesn't charge the batt.
I would verify that the battery will take a charge. If the battery is bad, the charger will tell you that it is not charged. It will not tell you why, just that it is not charged. If not plugged into the computor,again, battery is not charged. Hence, the beep.
Good Luck and hope this helps.
Posted on Mar 15, 2009
leecom72
  • 4806 Answers
SOURCE: Acer aspire laptop won't charge
First of all you have to determine whether it's the battery, charger or the laptop itself.
Remove the battery and boot the laptop on AC power only, if the laptop boots up you can rule out the charger and the laptop, you may need a new battery if that is the case.
Regards.
Posted on Sep 08, 2009
SOURCE: Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Posted on Jan 09, 2010
AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
So your saying the charger will charge the battery, as long as the laptop is off...But when it is charged, you remove the ac adapter, start up the laptop, running on battery power alone, then hook the ac adapter to it, and the laptop cuts off..???
Apr 27, 2014 | Acer Aspire 8930G Laptop Charger...
Asus a3a laptop
Probably the AC Adapter is no good....Go to e-bay and purchase a new AC Adapter for that model # notebook. But if it shows charging then try first by taking out the battery and see if the AC adapter will run the computer without the battery in it (if so, then the adapter is good, the battery is actually bad, so replace the battery instead).
Good Luck.
Nov 29, 2013 | ASUS A3Ac Notebook
Hp pavalion dv6550 runs on charged battery but not on adapter and does not charge the battery either. When the AC adapter is connected the blue light comes up so I'm assuming it is powered and con
Try another cord/charger with the EXACT same power specs as the original. Has the AC jack in the laptop been damaged, loose connection, due to pulling on the cord while plugged in? Try to wiggle it when plugged in to see if there is any connection. The AC jack may need replacing, if your lucky.
Apr 07, 2013 | HP Pavilion Computers & Internet
Asus ASUS A53U-ES21 wont power on
In order for the AC adapter to work the battery must be in good condition, why? Because the system runs of battery the AC adapter just keeps the battery charged up while in use, if the battery is open or defective the computer will not run on just the AC adapter.
Jul 12, 2012 | ASUS Computers & Internet
My sons Dell Vostro 1500 has a problem with the AC adaptor. It will run the laptop but wont charge the battery. Any help will be appreciated. Thanks,David
If it will run off the AC Adapter but won't charge the battery then odds are it is the battery that won't take the charge and not the AC Adapter's inability to charge anything.
Google "dell vostro1500 battery" and change to shopping. You will see many available knock off battery's starting at 20 dollars.
Although AC Adapters go out too. They last a lot longer than batteries do. Today's batteries just don't last. I would say average life span is a year to a year and a half.
Jan 28, 2011 | Dell POWER SUPPLY Power Supply
I had the battery not recognized on boot up. then
the Dell AC adapter has a sensing pin so the bios can determine the wattage of the adapter. If the system cannot ID the adapter, the battery charger circuit is disabled. You'll need a functional DELL ac adapter to get the battery to charge
Sep 26, 2009 | Dell Inspiron 1501 Notebook
Laptop battery not charging wanna know how to run without battery
The problem you described here shows that, the case is not likely to be a battery problem, but the laptop AC-Adapter (Charger) problem, because, the red light you are seeing shows that your battery has rundown, and even when you plug-in the adapter to AC, it still blinks red, showing that the AC-Power is not charging it. I would suggest that you get another Laptop AC-Adapter (The Charger), or try it with a friend's own first, then you'll see that the problem might not be with your battery but your AC-Adapter
Jul 09, 2009 | ASUS Computers & Internet
Battery won't charge
This is true, you will not be able to charge the battery without the correct charger. For mostly all laptops, when the charger is not maintaining a charge, it is time for a new one. However, it does not have to be the manufacturer's adapter, but I recommend purchasing the battery made for the Compaq Presario M2000 Notebook.
NextTag.com has decent deals on these adapters. http://www.nextag.com/ac-adapter-compaq-presario-m2000/search-html
I hope this helps. Please let me know if you have any other questions.
Thank You, Raph30
Jan 25, 2009 | Compaq Presario M2000 Notebook
Dell Latitude D510 Notebook Logo
307 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
