Question about Dremel Variable - Speed Multipro Rotary Tool 395
Dremel 395 in the middle of drilling sea glass and the collet and bit stop turning while the motor is still running fine! GRRRRR Thanks for any suggestions!
  • 202 Answers
Sounds like the rubber connector between the motor and collet.i use rubber tubing and hot glue to keep it working. bad news is you have to disassemble it to install a new connector.
Posted on Jul 13, 2009
New to buy collets for Proxxon TBM 115,
You can get the collets from Proxxon 920-757-1718
Oct 12, 2012 | Proxxon MICRO Drill Press TBM115
Dremel 3100 won't release the drill bit. Button at the top is pressed in and won't come out.
The button is only to keep the shaft from turning while you loosen the collet (the nut) with the little wrench. THEN the tool comes out.
Sep 25, 2012 | Dremel Variable - Speed Multipro Rotary...
I cant loosen the bit on my dremel variable 395. The hole that the 'stop rotary pin' enters which stops the shaft from spinning is stripped out. The pin will not stay in place when I attempt to unscrew the...
Clamp the bit in a vise or with vise-grips (you will probably ruin it) to hold it while you loosen the collet. You can disassemble the tool and get the lock assembly P/N 2615297356 from for less than $2.00. Search for the part number on line for a source.
Jan 06, 2011 | Dremel Variable - Speed Multipro Rotary...
How do you attach "multipurpose cutting kit model 565" to the dremel multipro model 395?
Remove the collet nut and collet then unscrew the sealing cap (black plastic ring), this has the same thread as the inner of the multi kit tool, so just screw on the tool then replace the collet and nut
Sep 14, 2010 | Dremel 395 Variable Speed Multipro Rotary...
Broken Dremmel tool spindle stop turning but motor runs
I called Dremmel tech support FOR FREE and they told me what was broken - flex coupling between shaft and spindle. Only Dremmel model 395 type 2 and 3 have these couplings. Mailed out repair kit yesterday.
Dec 23, 2009 | Dremel & Stylus Lithium Ion Cordless...
My Dremel lock nut won't budge. My collet is stuck! How can I loosen the bit?
You'll need to use either the built in shaft lock to hold the collet in a fixed position, or use a pair of slip joint pliers to hold the shaft of the bit, while you use the wrench to loosen the collet. Slow and steady should get it loose. Another option is use some penetrating oil sprayed lightly onto the back of the collet to help loosen it from the shaft etc.
Jul 17, 2009 | Dremel Variable - Speed Multipro Rotary...
My dremel tool runs fine (the motor)but the spindle stopped turning. Bumping it a few times will sometimes get it started again.
there is a tubing connector between the collet and the motor, they hot glue these together. i just go to the auto parts store and get a new piece of tubing and glue it the same way.you will have to partially disassemble it to replace the coupling. if you disassemble it the collet just lays in the housing on the motor side cut the tubing to the right length. a slightly smaller size won't need the glue.
Jul 12, 2009 | Dremel 395 Variable Speed Multipro Rotary...
Craftsman rotary tool doesn't lock down on the bits.
the collet is either the wrong size for the shaft on the attachment or is missing alltogether
Jul 04, 2009 | Dremel Variable - Speed Multipro Rotary...
Motor runs, collet doesn't turn
get a hot glue gun and go to your local hardware store and buy a piece of tubing to fit the collet shaft fill with hot glue and press it on the shaft.
Jun 19, 2009 | Dremel Variable - Speed Multipro Rotary...
I can't get the head to open to take out the bit
Unplug it, then while pushing in the little silver button near the head use a wrench on the hex nut and turn counter clockwise about a 1/2 turn. Push the bit in, then pull it out (that releases the little fingers that hold it).
The silver button locks the head so it won't spin while you are changing bits. Always be sure it is released before plugging in or turning on the power.
Feb 19, 2008 | Dremel Variable - Speed Multipro Rotary...
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
360 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
