Question about Maytag MDE2400A Electric Dryer
Maytag Neptune front-load dryer no power to control panel.
I have a Maytag Neptune front-load dryer model: MDE5500AYW. Serial #: 10487099ZB. Was using it yesterday with no problems, even fully finished dtying a load. Went to load a second load and the interior light was on but there was no power to the control panel.
I unplugged and plugged powe cord back in -- nothing. I reset my circuit breakers in my house, nothing.
I opened the door to see if the drum was somehow stuck or lodged but the drum rotated freely when I manually turned it.
The issue is that the on/off power panel and all cycle options on the control panel are not illuminated and do not work. Any ideas?
5 Suggested Answers
SOURCE: my neptune dryer has an interior 'fin' that is
There are screws holding the fins on the outside of the drum. To get to them:
  • remove door
  • remove screws on the opposite side of the door screws (which would hold the door if it would open to the opposite side)
  • pull the top of the front panel, which was held by those screws outwards
  • remove the front panel. You'll see brackets holding the top of the dryer in place. Remove screws holding those brackets.
  • lift the top.
Good luck
Posted on Oct 20, 2009
hunter19_46m
  • 7482 Answers
SOURCE: Dryer is making a grinding sound once ever rotation.
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers is in need of lubrication.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
Posted on May 19, 2010
Testimonial: "Thank you for the assistance. The actual problem was a bolt that had come almost completely off of the drum, this bolt was scraping against the side of the dryer. It was helpful to know that I could take the top and front completely off to get to the problem. Tightened everything up and everything works."
  • 122 Answers
SOURCE: Maytag Neptune MDE5500AYW panel lights work but not dryer
inside the control panel is a tech sheet that has some diagnostics on it . there is a membrane button test or something to that effect. I suspect that the start/pause button is the problem and you would need to replace the console w/touchpad.about $130-140 new. there are some used ones on ebay.
Posted on May 20, 2010
mc1bean
  • 3053 Answers
SOURCE: I have a maytag neptune
Hello, regber I was trying to help you out here. I wasgoing back to some customers that asked questions in the past and it appearedthat no one answered them, so I thought I would take some of my personal timeto see if I can help. Here is a link to about everything you want to know aboutyour dryer, from repair to trouble shooting it. If you go to this link andclick around, I am sure you will find out so much about your dryer, you willknow more that the company that made it. Here Is the link for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helped you at all, if youcan find the time to rate my help and some kind words written would beappreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
Posted on Oct 26, 2011
MDE5500AYW Maytag Neptune not heating. Heating Element, both high limit thermostats and thermal fuse have been replaced. What could be the problem?
Firstly, you have not mentioned that you have verified the presence of a power source of 240 volts, so make certain of that issue. If you have proper voltage, then the motor centrifugal switch could be at fault
Below is a link for trouble shooting your model.
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-4-563862-/Maytag-Dryer-not-heating-MDE5500AYW?r=%2fShop-For-Parts%2fa8b4d563862%2fModel-MDE5500AYW-Maytag-Dryer-Parts
Sep 28, 2016 | Maytag Dryers
Dryer running fine but just stopped heating. lint traps all clean.Maytag Neptune MDE5500AYW. HAVE THE DOOR AND FRONT PANEL OFF ALL ELEMENTS LOOK CLEAN AND ATTATCHED. No problem with home power...
Hi,If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.if you dryer is gas check out this gas no heat tip....If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 23, 2011 | Maytag MDE5500AYW Electric Dryer
May 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How do you open the top of a Maytag Neptune dryer model #MDE5500AYW
unplug the dryer,open the door and you'll see 4 screws,2 holding the door on and 2 opposite them,remove them and the door,now pull the front off you'll see a clip that looks like an L with a screw through it on each side,take the screws out and lift the top up
Feb 10, 2010 | Maytag MDE5500AYW Electric Dryer
My Maytag dryer model number MDE5500AYW has lights on, but won't switch settings. It is stuck in time dry at 18 minutes. Yesterday it was on sensor dry 47 minutes. Do I need a new control board inside...
OK, your control board and LED are integrated, so you will need to just replace the control board. I would try a hard reset before replacing the board. Pull the plug or, shut down the appropriate breaker switch for 5 minutes. Re apply power after the 5 minutes are up. if you continue to experience this fault, replace the control board asap.
CONTROL PANEL(CLICK HERE TO ORDER)
Aug 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer just stopped working in mid cycle.
Verify there is still power at the wall and check the thermal fuse.
Eric
Jul 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My maytag will not run
My neptune dryer electric mde5500ayw will not start the button seemed too be struck, and how can i take the side panel off to check the fuses inside
Nov 20, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag MDE2400A Electric Dryer Logo
852 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
