Tv is on makes a pop then turns off the back on.
  • 1 more comment
  • ksksbabb Jul 13, 2009
    mitsubishi CS-35503
    do i need to take it to a repair shop or can i fix it myself?
    Thank you
  • 3,037 Answers
You might have a power surge if there are a lot of plugs, try plugging your tv into the wall socket if its on a extension you are more likely to have a surge.
If that doesn't help, then your problem is either your lamp or your ballast. When was the last time you changed your bulb? What is the make and model number of your TV?
Your fist best bet is to first buy a bulb to see if it fixes it, if not you don't lose much because you ALWAYS need a backup lamp.
Benjamin
Posted on Jul 13, 2009
  • Benjamin Patri
    Benjamin Patri Jul 13, 2009
    Alright, disregard everything I said above in the second and third paragraph since this isn't a projection tv like I was lead to believe.
    There are several circuits in the tv that could cause this in this tv. It could be a tube or the convergence circuit or
    something in the power supply. Somone would have to open it up to check, make sure it is unplugged, you will probably find a burnt part. Either way, I wouldn't even bother fixing it since it is an older model that may just be too much hassle finding spare parts and not being cost effective and I would go with a new LCD tv if you can afford it since electronics are continually becoming cheaper and they are generally quite reliable.
    Benjamin
  • Benjamin Patri
    If you truly want to fix it, it would only be cost effective probably if you did it yourself as shops will charge $50 just to take it to look at it but only someone with electronic experience should fix it.
The TV menu options keep popping up aprox. 15 mins after turning the TV on.
Do a reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jul 09, 2017 | Televison & Video
Magnavox tv makes popping sound then lose sound. What cause this
Look first to see if same issue when playing a DVD etc connected to a rear audio/video input.
It may be the audio circuit in the set---got a model number?
May 29, 2012 | Magnavox Televison & Video
My screen indicates hdmi 720p on the top right corner then the video menu pops up. it goes back and forth making watching tv unbarable. also the volume flashes when it is pressed i have a Hesense 32 inch...
The HDMI 720p pop up,because on the tv Menu setup OPTION,U pick YES on the tv Program Title Display option,pick NO should stop the pop up HDMI 720p indicator.The volume bar indicator pop up when it press the button to turn volume up or down it is mornal functions of the tv.
Apr 04, 2011 | Televison & Video
42'' lcd turns on no picture/menu
Your tv is being attacked by electrical surges which seem very violent and has already damaged some logic controls. Please invest in a AC filter which will protect your tv from such spikes....... but first you need to get your tv serviced from the electrical damaged it has already suffered.
Nov 02, 2009 | Philips Televison & Video
3232 polaroid tv,makes popping noise when i turn it on.
this sounds like the problem most LCD tv's get with swelled up capacitors in the power supply board. look for circular cylinder shaped parts rapped in plastic with writting on the sides, and metal tops, if the top is rounded over, not flat, it is bad. replace them.
Jun 25, 2009 | Polaroid FLM-3232 Television
Tv making strange noise
Then just turn it off, if the popping irritates you.
As for why, I guess it just keeps turning on and off the speakers when it turns the light on and off...
May 19, 2009 | Panasonic Televison & Video
TV Pops & turns off
There are no tubes; generally the pop happens because of high voltage. It is being shorted out and the pop is either the flyback transformer or the horizontal transistor oscillator. these two are reponsible for creating the high voltage cycle for your television; when either of them or their circuitry is shorted out you hear that "pop" which is the emergency cut off circuitry coming into play to protect the rest of the television.
May 17, 2008 | RCA Televison & Video
32 RCA makes popping sounds
It needs a new FLY BACK transformer. That is what you are looking at. The origionals are not made for the set any longer but insist on having a generic on installed by a local TV shop. I just put one into a RCA 31" and it works nice. Don't throw away the TV. Get it fixed. MAKE SURE YOU INSIST THEY USE THE GENERIC ONE! THEY DO WORK!
Sep 15, 2007 | RCA E13320 13" TV
Popping noise
The anode cap on the back of the tv tube is leaking the high voltage be careful as going into the back of a tv it store very high voltage and could be fatal.the solution to problem get a tube of clear or red silicone discharge the high from the tube,you do this by getting a alligator clip with wire attach clip to a ground wire on the back of the tube attached the other end of the wire to screw driver gently push it under the Anode cap you will hear a popping sound with i little sparks. remove the cap from off the tube get some alcohol wipe the dirt away apply the silicone around the anode and the anode cap place in on back and leave it to dry and cure for about 7 hrs close up back and turn on your tv and all the popping sound is gone.good luck.but if it is the wire for the anode cap that comes from the flyback is the one leaking change the flyback.again good luck.contact me on fixya.com or email me at nicodhem@yahoo.com
Apr 24, 2007 | RCA 27V520T 27" TV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
