Noisy and inconsistent cooling
I have only had my heat pump two days and the cooling is very inconsistent. You can turn it on and it works okay, doesn't get extremely cool but does the job. The outdoor unit stays fairly quiet when the unit seems to be cooling. After the unit shuts off and we turn it on again, it doesn't get cool and the outdoor unit is extremely loud. Someone mentioned to us that it could be the reversing valve. It is not low on freon. Its like the luck of the draw you can turn it on 3 or 4 times and it wont cool or you can turn it on once and it works. What temp. should the air be coming out of the vent? Any advice would be helpful. Thanks
    Scholar:
  • 91 Answers
It could be that there is a problem with the Thermostat\low voltage switching. Some heat pumps have reversing valves activated for cooling , sometimes for heating. Whoever installed this for you is totally responsible for your unit still. There can be a number of things going wrong, like no filter drier in stalled and sporatically clogging the refrigerant and making a lot of noise. Call the installer back.
Posted on Jul 13, 2009
Inconsistent power
If it's totally dead, the main fuse may have blown. However, since it was inconsistent before it went dead, it might lead me to think that you have a loose connection. Sometimes they heat, lose continuity, and then work again when they cool. A defective thermal protector might also cause this.
Dec 20, 2013 | Whirlpool WMH1163XVS Microwave Oven
Heat Pump - blows heat to set temp, then off, then kicks on to blow cold
Heat pumps defrost which is the AC mode, if the heat strip isnt working during a defrost, the air will be cold, A heat pump only feels warm if the heat strips are on too! the refrigeration cycles heat output is much less sensible to our 98F skin. heat pumps that satisfy a room setpoint are working at least, all heat pumps feel drafty to most.
Oct 28, 2012 | Honeywell Programmable Thermostat Heater
Heat/Cool gauge fluctuates inconsistently
You might check the coolant level after the engine cools,if it's low add 50/50 mixture of coolant and water. Keep an eye on the level to see if it happens again. You might have a small leak in the system. Good luck
Jan 18, 2010 | 1998 Volvo S90
GE side by side gss23qg gss23qs: Freezer is not working, building up frost, ans is noisy.
If you hear the compressor (underneath the refrigerator) running okay, you need to check around the compressor and see if the compressor fan is turning. If this fan does not turn, heat is not removed from the refrigerant coils as it should be. This greatly lessens the cooling ability of the system.
If this fan is not turning, you will have to replace the fan motor.
Oct 15, 2009 | Refrigerators
NOISY FUEL PUMP ON 650 YAMAHA VSTAR (2002)
your fuel pump suppose to Hum and gently vibrate only when working normally, clacking sound would only mean that it is having a hard time or inconsistently supplying gasoline into your engine. Have it checked and see if any improvement would happen.
Nov 25, 2008 | 2002 Yamaha V Star Classic
1987 Toyota motorhome 22RE engine cooling inconsistent
I think you have a leaking head gasket, very common on this engine.
Sep 22, 2008 | 1987 Toyota Pickup
Noisy frig
it could be that your cooling fan gets noisy at times and stops for a while you could try to put oil on the shaft behind the fan this will help when it does get noisy pull the fridge kisten to the motor if noisy replace it its not to expencive about 40.00 dollaresthanks from gilles
May 12, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Noisy defrost cycle thumping
The heat pump works like this. Your outdoor units are now your evaporator, meaning that now they get cold, they will build a layer of ice and they will need to go thru a defrost cycle, either iniated by time or temp. When the cycle starts your system actualy switches back into cooling, turns off your outdoor fan, and brings on your heat strip. The noise you hear is either you reversing valve switching or the ice being melted, then being sucked back into the fan when your unit switches back into the heat mode.
Nov 16, 2007 | Heating & Cooling
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
