Question about Kenmore 24 in. 16539 Built-in Dishwasher
Element is broken & dishwasher smells when dry inside
Here is my situation:
Kenmore Dishwasher Ultrawash * Sensor ATC * GT * QuietGuard3 *
Stock# 16502
Type 575-0
Model 16502200
Serial FM4403927
E71195
It only smells when completely empty or while the dirty dishes (pre-rinsed by hand) are collecting until time to run a cycle. Once run the smell goes away until it dries up again.
The dishes don't come out very clean anyway even before we noticed the smell a few weeks ago.
Was going to do the "bleach" tonight but read these posts and decided against that. I looked at the element and saw it was severed in half.
I checked for food, cleaned under the doors, etc.
Can you help me out???
Thanks!
Russell C
SOURCE: Kenmore Elite 665 16912001 Dishes not completely dry.
you can check for the elemant open. it will have to be pulled out.the connection may be bad to the heater.
Posted on Oct 31, 2008
jonniewalker
  • 1031 Answers
SOURCE: Kenmore Dishwasher 17369 not thoroughly cleaning
The first is to look for filters and drains to clean. Also check out the jets, as sometimes these can be clogged farther back than you can see with a quick inspections. You can likely remove them and take a good look. Secondly, you may want to switch detergents. Perhaps the quality of the water you are using has changed, hard water build up or you have changed detergents. You have to find the right detergent for the kind of water you are using, especially if you don't have a water softener. where the filter in the bottom of the dishwasher needed cleaning out. Just take the screws out, pull the plastic filter out and clean. Hope this helps. Report
Posted on Apr 19, 2009
MNfisherman
  • 11896 Answers
SOURCE: I have a kenmore ultrawash-quietguard3.
for kenmore elite, ultrawash models, try pushing hi temp scrub, then air dry, then hi temp scrub, air dry - all lights should come on. Close door and hold in start button for 5 seconds or so - display will show 'd1' and it will go through a diagnostic cycle.
heat wash then heat dry, repeat once, all lights should be on now. Close the door shut and hit 'start/resume'. It should run through a quick, what appears to be a diagnostic, then machine should start
Posted on Aug 20, 2010
heatman101
  • 43501 Answers
SOURCE: My kenmore ultrawash quitequard 3 is not cleaning or heating up
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
ggjk
Posted on Sep 29, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite dishwasher 655.16463300 not cleaning dishes
The inlet screen is at the bottom of the unit. Clean it out and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Dishwasher will not start
Unlock dishwasher if locked by holding heated dry button for about 4-5 seconds next quickly hit the following buttons in successive order heated dry, normal wash heated dry then normal wash this should run diagnosis of the unit. Wait about2 minutes then press the cancel/drain button this should reset it and restore operation be sure to check that water supply is on and the drain is clear or you may get the code again.
Dec 07, 2013 | Kenmore 24" Built-In Dishwasher with...
Kenmore dishwasher does not dry
The first thing you should do is to turn off yourdishwasher. After that take your Kenmore 16762 Dishwasher manual and make sure ifheating element (calrod heater) is still functioning (it could be broken or burnt). In that case your dishwasher will not keep water hot during washing cycle). If you need manual you can download a copy here!
Jun 03, 2011 | Kenmore 16762 Dishwasher
Our dishwasher Ultrawash Quietguard3 will not drain the water. We have misplaced the book. Any suggestions?
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Apr 15, 2011 | Dishwashers
No power to the dishwasher
Remove the kick plate, there is a box where the power enters on right, If you have power than its most likely the control board. We have em and will assist you on the phone 704-819-6557
Mar 14, 2009 | Kenmore 24 in. 17032 Built-in Dishwasher
heatman101
ggjk
Feb 14, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Won't start
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Jan 13, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore Quietguard Plus/Ultrawash - Kenmore
drain hose may be partially clogged or kinked up. ensure that the hose is not bent up thus restricting the flow of water out.
Nov 26, 2007 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore ultrawash dishwasher
little nip Most likely the problem with your dish washer is one or more pads on the control panel are shorted. To fix it the control panel has to be replaced. If you are going to do it yourself, I need the complete model number (on the door frame) and the color for the panel. Then I can find the best deal for you. Gendos...post back
Feb 01, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
Kenmore 24 in. 16539 Built-in Dishwasher Logo
181 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
