Question about Toshiba 57H81 57" Rear Projection Television
Picture Jumps/flashes for first 5 minutes
I have a Toshiba 36HF72 that when turned on for about the first 5 minutes has a horizontal flashing/jumping/jittering that "tiles" or scrambles the picture. After it warms up the picture has slight vertical (up & down not side to side) wavy lines throughout the picture but mainly noticable at the top. The picture continues to flash every once in awhile (especially when the vcr is playing). The horizontal & verticle deflection sections have been resoldered as well as the power supply section. Freeze spray has no effect on the board after warm up. Tapping, shaking, or flexing the board has no effect nor does probing with a plastic stick. The problem seems to be gradually getting worse. Any suggestions would be greatly appreciated, Thanks :-) Jumping, wavy picture on DVD or VCR, HD DVR works great when set to 1080i only.
  • huntermark May 15, 2008
    Same problem on my Toshiba 57HX81 purchased six years ago.
    After five minutes of warm-up (after initial power-up) it goes away.
    The jitter is side-to-side and mainly at the top of the screen.
    -Mark Hunter
  • 87 Answers
There is a module called a hyper board that is vertically mounted near the jack panel. Inside the module are 10mf/25v capacitors they are grtting weak. The module is fully shielded and pluggs into a socket. the module has 4 tabs (2 on each end) that must be unsoldered before it can be unplugged. This repair should be done by a qualified technician. The caps are surface mounts and very small. Unless you have excellent soldering skills and a rock steady hand DO NOT ATTEMPT to repair this problem on your own.
Posted on Nov 25, 2007
Toshiba CZ32V61 no picture
1) you have problem with the Raster
2) the main causes are a) raster b) picture c) sound d) synch
3) since this are not video, the problem is raster. your must
test the voltage from section horizontal out +125vdc+vertical output +80v+all other circuit +12vdc
4) test the power supply for defective. see the diagram attached
Jul 12, 2012 | Toshiba CZ32V61 32" TV
Toshiba Picture Not On
what you suggesting is that the lcd has a good maintenance needs that have to have cold solder or connectors are sulfated
Aug 22, 2009 | Televison & Video
Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Apr 24, 2008 | Toshiba 27D46 27" TV
Toshiba TP50H95 No sound no picture
Sounds like a problem in the deflection circuits either vertical or horizontal. You may also want to check the solder connections in the tuner as they have been known to develop cracks over time. But the prior shrinking tends to say deflection problems.If I can assist you further please let me know.
Feb 03, 2008 | Toshiba 50H81 50" Rear Projection...
Is my Toshiba 57H81 worth repair?
Bounce horizontally usually means up and down,which relates
to the vertical output IC. Solder IC301, IC401 pin connects==try
again.You can easily isolate "bounce" problems by lightly
tapping on the vertical IC heatsink....Let me know if you need
further assistance.....T.
PS. Though hard to find, a qualified tech could do that repair
in home for 300. to 400.00...
Oct 20, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 32A43 Horizontal Bars, pop, no picture.
First of all, there is no such thing as a "high power flyback converter". There is a flyback transformer, but if it was bad you would have absolutely no picture at all. The fact that you dont even know what the basic components are suggests that you should not be "diving in" to someone else's TV. Do everyone a favor and allow an experienced tech to service the set.
Jul 24, 2007 | Toshiba 32A43 32" TV
I had the same problem and followed the instructions from Jack and my 57h81 is bak up and running. Thanks Jack. RonD
Jul 02, 2007 | Toshiba 36HF72 36" TV
Wavy Screen on Startup
I gather from your post that wavy can mean two possible things as the TV comes on, you see the picture flow like ocean waves? In this case you may have 60Hz hum modulating with the picture, this is actually unlikely these days, but I have heard it happens sometimes. The other thing it could be is light horizontal tearing. This happens when the horizontal frequency is too high or too low. You are not going to like my solution because I feel that for problems like this the set must be analyzed not just subjected to "shotgun troubleshooting", so here I go, Take the TV to a repair shop.
Feb 28, 2007 | Toshiba 50H72 50" Rear Projection...
4 yr old Toshiba jumps when turned on
take it to a tech if you have not done so. your problem is lose solder.your board needs to be rsoldered over to connect your component properly over the years heat from the operation of the tv cause the soldr to lose grip on the board.good luck
Jan 07, 2007 | Toshiba 36HF72 36" TV
Toshiba 57H81 57" Rear Projection Television Logo
266 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
