Question about Dishwashers
DS605 has had flood switch activated, how do i turn it off
The dishwasher started flashing with the fault code F1, and i've looked all over the internet to find out how to fix it but all i find is user guides and to call repair guy
anyone have any idea's how i can turn it off myself without calling out someone, last time i did they ripped me off big time for the amount of effort they did.
  • 64 Answers
Well ds is a single drawer if you look at the drawer from the front you well see on the side of the drawer a push in clip push in and gentaly pull slowly towards you then you have accses to the botton clear the water then put together hope this helps
Posted on Jul 14, 2009
Dishwasher error f1
The manual states that fault code F1 means that the flood switch has been activated. They recommend turning off the water and power to the unit and calling them. Their phone number is: 1.888.936.787
http://www.fisherpaykel.com/vault/pdfs//pdf_usecares/529543CDD605userguideUSCAw.pdf
Nov 26, 2013 | Fisher and Paykel DishDrawer DS605FDSM...
How to reset the flood switch on a fisher & paykel
Hi - unfortunately my good friend it cannot be reset as one would like quite easily anyhow... water has found its way to the base of the drwaers and have activated the flooding switch - one could pull it apart to dry it - tip the water out from the base but if the leaks not repaired you will have the same problem later and will be on-going.
5 Fault Codes
Fault Code LED Display Fault Possible Causes
F1 ----#
The flood switch has been activated.
A leak has occurred in the base of the dishwasher.
Cause
 The fill valve has failed open.
 The flood switch is faulty.
 Excessive water has been added to a wash sub cycle, indicating leaking seal or siphoning.
hope this is useful tp you - let me know if you require further asspstance...
Jul 16, 2011 | Fisher and Paykel DS602 Dishwasher
The Machine is flashing a F1 fault code the manual say's to turn off power and water supply and ring service centre. Is there a code sequence to get it back to start.
Generally it means the flood switch under the drawer (inside the housing is activated). This means water is leaking from somewhere - foam in detergent, cracked or crinked hoses, door seal leak etc.
To fix, take the drawers out from housing and dry the flood switch located in the centre of the housing base. Need towels and hair dryer.
Make sure the power is turned off.
Jul 04, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher keeps flashing F1
F1 on your dishwasher is the fault code for leaking inside the machine. the water has caused the flood switch to activate. have you put any detergent rather than your normal dishwasher detergent into the machine? if you have, the water probably leaked out of your overflow, if not, then you have a leak on the top drawer or bottom drawer. the easiest way to check is to leave the machine off for a couple of days until it drys then turn on the bottom drawer to go thru a cycle.if the F1 comes up again then the problem is on your bottom drawer. if F1 does not come up then try the top drawer. please reply if you require further help.
May 28, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have a single draw Fisher and Paykel dishwasher. I stupidly put washing up liquid in the dishwasher which resulted in a F1 problem. Water started leaking under the draw and onto my floor. I turned the...
ok , F1 means your flood switch has activated, which is underneath the drawer. now they show the F1 fault because of 2 reasons.1st there is still water underneath drawer causing switch to activate. 2nd your activator board which has the flood switch attached is faulty reading your posting it has been about 15 days since the fault happened. the water should have dryed around switch by now. if there is power to the unit and it is still coming up with F1 fault then possibly you have damaged the activator board. please reply and tell me if you have power on or off at the present time. to fix the problem it is alittle bit involved but i can guide you thru it when you reply .good luck
Apr 23, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
F1 fault
F1 code would mean the flood switch is activated.
In Nautilus people have found this to be caused by a faulty door seal.
Water seeps under the diswasher base panel and finally the flood switch (a protection) activates.
The solution is to replace door seal after drying out under the base panel.
Apr 22, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 fault on a ds603
The reason for your F1 fault code in your dishwasher is due to the flood switch that has been activated in your unit. The best way to solve your problem is to turn off the water supply and power supply to your unit and call an authorised service centre. These problems cant be fixed on your own.
Apr 05, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 display flashing?
Flashing wrench means a fault code has been triggered.
F1 is the fault code when flood switch at base of dishwasher cabinet turns on.
This can occur due to several reasons when moisture gets to the base of the drawer cabinet.
You will have to turn the power off and extend the drawer out as much as possible to expose the back of the cabinet. Take towels and a hair dryer to dry the base. Once the flood switch gets dry the problem will go away.
The main thing is why did the water get there. You could have a crack in the hose or simply the detergent may have caused too much foam.
Jan 07, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and paykel diswasher f1 fault code
f1 fault code means the flood switch is activated. There is moisture at th e base of your dishwasher.
Dec 07, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the...
Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the other and the are both giving the error of the activated flood switch. Any advice or instruction is greatly appreciated.
Jul 22, 2008 | Dishwashers
Dishwashers Logo
122 people viewed this question
Top Dishwashers Experts
