Question about Dell Computers & Internet
My display has a red tint to it
I have a Dell LCD Monitor. All of a sudden, the entire screen has a red tint to it.
  • 77 Answers
Try adjusting the color properties of the monitor using the controls located on the front of the monitor.
If you can't correct the color, then it's a problem in the color circuit. As an ex tv repair guy I can tell you it may cost more than the monitor is worth to fix it unless it's still under warranty.
Posted on Jul 13, 2009
My hp pavillion dv7 1245dx screen has a red tint in the background?
Your lcd screen is bad. It's either the lcd screen or the video card inside the computer, but most likely the screen. You can isolate the problem by connecting an external monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok without the read and green tint then your video card inside the computer is good but your lcd screen is bad. If the Borrowed monitor displays the same red and green tint then the video card inside the computer is bad.
It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
Jun 05, 2012 | HP Computers & Internet
Red screen on E152fpc monitor
A red or pink tint on LCD monitor indicates that the CFL backlight bulbs are failing. These are just like the florescent bulbs you use at home and the office but much smaller. When they are about the fail they will have a red tint to the light instead of white. They can be replaced but on a 15" LCD its not worth the price and trouble to do it. The bulbs will run about $35 and then about 1 hour to install if you know what you are doing. It would be better for you to get a replacement monitor.
May 07, 2012 | Dell E152FP 15" Flat Panel LCD Monitor
Red tint on Viewsonic P930b
We do a lot of LCD monitor repairs and usually when you get the red tinted display it means the backlight tube is going out. This part is like a very small fluorescent tube just like in you office lamps. The tube is part of the display section and is very hard to replace. You can check the power supply first just to be sure. We have a dis-assembly/repair guide on our web site at: www.ccl-la.com/badcaps.htm If you find any bad capacitors you can change them and check but I would be it is the backlight tubes, if so just replace the monitor.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Jul 20, 2009 | ViewSonic VX924 19" LCD Monitor
Pink tint on Dell 1704FPT Flatpanel LCD
Unfortunately if you have tried a different machine (it could be a bad video card) and tried the cables most likely it is the screen itself. Typically when one of these lcd's begin to fail the pixles no longer access the blue field and you see mostly red instead of the other two colors. In short pink screen is terminal, it will last for a while longer.
Oct 01, 2008 | Computers & Internet
False color with Dell E151FPp and Mac Mini
a big issue with this..does the mac mini have the drivers for that monitor? only one way to find out..
www.mac.com has support and drivers, no?
Jun 16, 2008 | Dell E151FPp 15" TFT LCD Flat Panel...
The monitor is broken. The circuits that generate green in the RGB setup are not working. If its under warranty, replace it.
Apr 23, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Gateway FPD1960 19" CD has a red tint to all oc screen when I turn it on.
Make sure your VGA cable is seated properly. If it is seated OK, it could be the start of a problem with a backlight. When a backlight goes bad, it typically shows up as pink/red color where white should be displayed.
Feb 07, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Red screen?
If the vga cable nicely connected may be the logic card in the LCD.
Jan 06, 2008 | Star Logic 17" LCD Monitor
22-inch Wide screen X2Gen LCD Monitor
Monitor Help CH000241, No display on the monitor. CH000242, Distorted or skewed image on monitor. CH000243, Monitor has a tint of one color.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
546 people viewed this question
Alun Cox
