Error message is feeder paper tray 1
SOURCE: Paper Jam
Seems you have a dusty roller in the feed mechanism. try cleaning off the roller with some windex (or equivalent) on a towel.
SOURCE: No Paper Light wont go out
I had similar problem, but not exactly what you describe. The "no paper" light would come on when I would try to print labels in MS Word using paper tray #1.
I found and installed driver and firmware updates. Still the same problem. I could print the labels if I treated it like a normal document, but if I went into "envelopes and labels" it would always say "no paper."
I found that if I used the MP tray (the one behind the front cover) it never gave me the "no paper" error. I should have been able to use paper tray 1, but it wanted the mp tray for some reason.
SOURCE: unable to print 30 or 50
the encoder strip is probably out of its socket. its a long mylar strip that goes from one side to the other, and goes underneath the printhead.
SOURCE: I have a Brother HL-4070CDW printer and the
hello, sorry to say that your machine will need the entire front door assembly, whats happening, is that the guide for paper feed, well it now has problem, so far the only way to fix it, is to replace this part, i have tried alot of temp. fixes, but only last a few days, and then it comes back, sometimes worse.
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside for any debris.
3. If you're willing and physically able, you may also
turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the
table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris
that could cause this error or problem.
6. If cartridge area is clear, close the cover.
7. Unplug and re-plug the printer into the power outlet
to reset it.
8. When the printer turns on, reinsert the cartridges and
load some paper. Try to print again.
ns Serif"'>6. When the printer turns on, reinsert one cartridge
first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge.
Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
