Question about Cycling
Pedal turns not the wheels. the chain is turning too but its simply empty!
  • mericanmelic Jul 18, 2009
    very helpful advice. no choice but to the shop i go. thanks.
  • 34 Answers
Sounds like your freewheel or freehub body has gone bad. This happens on very basic bikes and when your have very high miles. The freewheel is an inexpensive fix however, the freehub body requires overhualing the rear hub and can be rather expensive. Either way you have to have special tools to fix this problem so you will better serviced to take the bike into your local bike shop for an estimate.
I hope this helps. Thank you
Posted on Jul 17, 2009
Petals turn freely with no resistance... is there a chain or belt?
if the pedals are direct to the wheel , there will be no chain
if the pedal arms are back from the wheel , it will be a chain which has probably broken or come off the cogs under the covers
The fix will be to remove the covers and see what has happened
Dec 31, 2015 | Schwinn 220 Recumbent Exercise Bike - 2012...
The pedals will turn but the wheel does not
The rear set of gears, called the "Freewheel" are shot, and need to be replaced. You can find another wheel, but this will probably prove to be difficult, or you can pay for a new freewheel or your bike shop may give you an old one for a discount.
Good luck
Joe
Aug 29, 2011 | Cycling
The chain doesn't move when the pedals are turned
Take you calibrated eyeball and evaluate what DOES move or what components of the bike may be preventing it (like brakes). Elevate the rear wheel so it CAN turn and rotate the pedals. I assume the pedals turn because you say they do. Is the chain even engaged on the chainring?
Jul 12, 2011 | Schwinn Cycling
Took chain off to remove wheel and am unable to get chain back on correctly. 2001 Magna oasis 26" 7 digit shifting speed. Unablew to locate manual...can you help?
Put the chain to the inside of the front cog wheel, beside the pedals, first but not onto it, so you have plenty of room for pulling the chain to the rear. Fit the wheel back into place and before tightening it pull down the spring loaded arm, with the small cog wheel beside the back wheel. This takes the tension off the chain and allows you to put it into place on the back wheel. Tighten up the wheel. When it's tightened fit the chain onto the top of the front cog wheel. Lift the back wheel off the ground and turn the pedals forward. The chain will click onto the front cog wheel when you have turned the pedals one complete turn.
If you need to see a picture of how it should look at the back you can see one at http://orangecounty.craigslist.org/bik/2409696114.html
May 29, 2011 | Cycling
My bicycles chain fell down,and I cant put in on again, Do you know some repairer who can repair it,around the Leytonstone or maybe near it? Many Thanks.
There's a trick to putting a chain back on a bike. First fit it onto the back wheel. Then hold it on the top of the front cog wheel (at the pedals) Get someone to lift the back of the bike so the wheel is off the ground. While the wheel is off the ground and you're holding the chain on the top of the front cog wheel turn the pedals forward, with your other hand, as when you're cycling and as it turns the chain will go on.
If you don't have someone to hold the back wheel up off the ground you could hold the chain on the bottom of the front cog wheel and turn the pedal backwards. The chain will still go on.
Nov 13, 2010 | Cycling
I tightened my chain by pulling my bike tire back and tightening the bolts and now every-time i pedal it either gets extremely loose or extremely tight depending on the angle of the crank pedals i dont...
Does your bike have a derailuer? (gears) If so, check that the chain is running though it correctly. Also check that your wheel is aligned correctly, you can check this by simply lifting the rear wheel off the ground and spinning it. If the wheel rubs on your frame, then simply loosening the bolts and tightening them up when the wheel is straight should fix the problem.
Cheers.
Jul 03, 2010 | Cycling
When pedalling the chain turns without driving wheel
you need a new coaster in the back rim. theres little gears inside that grab when you pedal forward and not backward. you stripped/broke the gears inside. take the back wheel off and if the sproket/cog spins both ways then you need to have it replaced.
Oct 20, 2009 | Cycling
Wheel does not turn when peadalled
needs a new sprocket on the wheel the teeth inside are worn
Oct 12, 2009 | Mongoose 20-Inch Gravity Games BMX...
The chain is not funcitoning correctly
Your chain is too loose, you need to get it tightned by shortning its lenght and get it greased.
Aug 04, 2009 | Cycling
When you pedal you dont go anywhere and everything is moving chain and gears
Your rear wheel freewheel assembly is probably shot and the easiest solution would be to buy a new rear wheel. Bring the old one in with you to be sure you get the right one. Most of these can't easily be rebuilt.
Jun 29, 2009 | Cycling
Cycling Logo
156 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
