Question about Stanley Air Tools & Compressors
I have a Stanley Ridgerunner that only fires one nail then it will not load the next one. what can i do to fix this
  • 108 Answers
Clean the tar out of the feed mechanism, you dirty roofer.
Posted on Oct 11, 2009
How do I load the stapler?
No you don't. We answer most things here.
If the stapler is like any of these
http://www.amazon.com/s?ie=UTF8&page=1&rh=i%3Aaps%2Ck%3Abostitch%20staple%20gun
You push the back in slightly to unlatch it and then drop it down a bit and the staple pusher comes out completely.
Jan 28, 2016 | Heavy Duty Stanley Bostich Heavy-duty...
Fires when air is plug in,driver stays out.
Most likely problem is the firing valve (tva6), easy to replace and not expensive. Good time to remove the head and lube headvalve with white grease. For now be sure to remove the nails after use and install nails after air connected. Good luck
Jun 20, 2013 | Stanley Bostitch N80CB Coil Framing Nailer
How to use?
What is the model of your Stanley Gun? What nails are you trying to load?
Tracy
Solent Products Air Nailing and Stapling Supplies
Mar 24, 2013 | Stanley Bostitch Nail Gun
I have just brought a brand new bostitch bt1855 brad gun that i tested once it arrived, and it worked perfectly. the next day it only fires air and no brad. there's no jam or obvious problem. any...
Rather than try to repair it or look into it, call the dealer or take it back to him as you will invalidate your warranty if you do anything to the unit, and that is not worth it. Let the dealer worry about it.
May 21, 2011 | Stanley Bostitch Nail Gun
Miss fire or fireing two at a time how to fix?
first check for the proper guage nails, then look for a jammed nail in the magazine area and also a bent driver and lastly make sure that when fired the piston retracts fully all the above will cause the misfire.
Jan 23, 2011 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Nailer fires first nail successfully but next nail jams. It appears the part that retracts after each nail is ejected does not retract all the way so the next pack does not load properly. Have cleaned and...
first make sure you are using the right guage nails. then I would look at the condition of the driver to make sure not bent, also look for a broken nail in the magazine area which will also cause this, lastly does the piston/driver "fall" in the cylinder?? there should be some resistance against the o ring, if not then it could also cause your described problem,
Dec 21, 2010 | Stanley Bostitch SB1664FN 16 Gauge...
I can get he gun to shoot 1 nail but won't load the next nail?
There is a small piston on the side of the magazine that pushes the feeding claw which pushes the next nail into place. Either the feeding claw or piston is stuck or the piston is worn out and needs to be replaced.
Sep 30, 2010 | Stanley Bostitch Coil Framing Nailer
Need help loading staples in my Stanley electric staple/nail gun
there should be a button / lever at the rear press it and it should open so as to insert the staples
Apr 05, 2010 | Stanley Staple/Nail Gun Elec
Bostitch nail gun loss of pressure, won't fire nail
Hello. I can help you. The nail gun you have uses 18 gauge brads. I would use only original Bostitch 18 gauge.
The one MM of difference you mention is the reason why you do not have the pressure you did have. Get rid of those 31MM brads and get the 18 gauge. Home Depot carries the Bostitch line. I would go there or to homedepot.com
May 20, 2009 | Stanley Bostitch BT200K
Air Tools & Compressors Logo
186 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
