Question about Kitchen Ranges
Oven takes sometimes hours to get to 350. We just had the oven on for 2 hours and it only got to 210. Sometimes it will heat up right away.
  • 54 Answers
It sound like your bottom element could have a crack or it is loose try screwing it in tighter and if that doesn't work take it off by unscrewing it and replace the whole heating element it is very easy to do . home depo or a appliance store should have the heating element.....
Posted on Jul 14, 2009
I set the oven at 350 degrees and after 3 hours it has only reached 185 and won't go any higher. The oven is approx. 8 years old.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jul 25, 2011 | Ovens
My oven takes forever to pre-heat and sometimes not at all. Is my heating coil shot?
If your electric oven is taking too longto heat or just not heating up right,then check out this tip that will givemore detail about your problem.
Oven ProblemsElectric Oven is Heating Slowly or Poorly
heatman101
Apr 17, 2011 | Maytag Ovens
Set oven to 350 takes long time to heat never hitting 350 after 1 hour of being on. flame comes on but never very powerful broiler and burners work fine.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Feb 15, 2011 | Kitchen Ranges
My Kenmore gas oven sporadically takes forever (30+ min. to heat up to 350 degrees). Sometimes it works fine, & other times it takes at least 1/2 an hour. Also, I periodically smell natural gas when I...
Sounds like a weak ignitor. If it doesn't get hot enough to allow the proper amperage through to the gas valve, you will have this symptom.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 25, 2009 | Kitchen Ranges
Oven Doesn't Even turn on
The oven thermostat controls the oven temp. It is not working and you need a new one.
Jul 01, 2009 | Roper FGP305 Gas Kitchen Range
Oven temperature does not get hot enough.
Hi, It sounds like the ignitor might be getting weak and opening the gas valve conditantly. Try setting a temperature and watch to see the ignitor glow. The flame should ignite within 30-45 seconds. If the flame ignites to heat rith away, it should get up to temp before shutting down.
I hope this helps you. Please let me know if I can assist you further with this issue.
Thanks
Vic
Jun 24, 2009 | Frigidaire Gallery 30" Self-Cleaning...
Oven heats very slowly
If your top burners work ok, regulator should be ok. Majority of times the fail part in the oven is the ignitor...turn oven on and check for a flame after 10 mins. small flame could mean a bad safety valve.
Jun 09, 2009 | Maytag MGR5870 Gas Kitchen Range
Oven
sounds like a bad ignitor, sometimes lighting and not relighting during extended cooking time. dies it take longer than a minute to ignite gas? more then 10 in to preheat? smell gas while cookin?? all signs of a bad bake ignitor
Mar 08, 2008 | Magic Chef CGR1110 Gas Kitchen Range
Kitchen Ranges Logo
101 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
