Question about HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive
CD Drive will not work
My CD drive will not load a DVD it makes a clicking sound when it is trying to load on to the DVD player.. but does not make contact with the player
Re: CD Drive will not work - HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001...
The drive is probably broken. replace.
Posted on Dec 13, 2007
0 characters
3 Points
My laptop is at region 1 and i want to change it to region 2 i have 1 attempt left
To changethe Region code on your DVD player, open Control Panel - System - Hardware -Device manager, and click on DVD/CD ROM drives, then right click on the DVDdrive and click Properties then click on DVD Region.
You can enter a new region and it also shows you how many changes have beenmade.
NOTE you can make only 4 changes and the player will lock permanently on the4th change.
If you want to play DVDs from any region you maybe able to upgrade the firmwareto make it region free BUT if you make a mistake or installed the wrongfirmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece ofsoftware (Passkey for DVD) that allows you to play DVDs from any region andPasskey for Blu-ray that allows you to play Blu-rays from any region. There areseveral available on the Internet but my favourite is DVD-Region Free From: -,free.htm
Apr 02, 2012 | E-Machines emachines (emachinees) CD-ROM...
My dvd driver wont work it is not even showing up on my specs
make sure that the dvd is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or your drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Feb 25, 2011 | E-Machines emachines (emachinees) CD-ROM...
Cd player on computer want play,compaq cq60-422dx notebook
try both of these steps, it should help
Please press the windows key on your keyboard , hold it down, and press R
Type in devmgmt.msc and press enter
If it asks to open, click yes.
Then, you should see a list of devices installed on your computer..
Double left click the cd dvd drive choice to expand it ... Then..
right click on each listing inside the cd dvd section..
And click uninstall.
Once uninstalled. restart the computer, and test the cd drive..
It should now be working in windows normal startup!!
If not, then try the following as well
Go to the link below.
on the page that comes up. click on the green run now box.
It will start a file download ( this file is perfectly safe as its directly from microsoft)
Once you download the file, make sure to run the file..
It will run a dignostic program that will attempt to repair and fix your missing drive
Feb 23, 2011 | Compaq CD Drives
I have a new HP - Pavilion dv7-3112sa Refurbished Laptop. The Disk drive is not playing DVDs or CD ROMs. It will play audio CDs fine but when I put in a DVD or CD ROM it just buzzes but does nothing.
It sounds like the drive may be bad. You may want to try getting any updates that may be available from the manufacturer. Also if it does not work you could try reinstalling the drive.
To do this go to start > right click on my computer or computer > select properties > click on the hardware tab > then select device manager > within the device manager look for DVD/CD-ROM drives > click the plus symbol on left > double click the cd dvd drive > this will open the dvd properties within here click the Driver tab on the top of screen > then click uninstall button. > Once uninstall ed restart computer. When the computer is loading back up it will reinstall the dvd drivers.
If this does not resolve the issue contact the PC manufacturer.
Oct 21, 2010 | CD Drives
Compaq cd drive not working. It worked originally
To find, and install Hardware, click to open Computer. From the Desktop check to see if there is a (“CD D :”) DVD RW Drive (D :) for “external devices, the drive maybe “different (E, F) in the Device with Removable Storage area. If the device is, present. Do the following to “setup” the player for “installation. Right click on (CD, DVD) Media Player, select (“Install”) follow, all instructions thereafter. If the area is (Blank), go to, and click on the Start button; click all “Programs” scroll for a Media Disk Player Do the same for setup (above) “Install.” “Did this solution help? If so Helpful Ratings Feedback is appreciated, thanks paul7of9”
Feb 10, 2010 | Compaq (120192-B21) CD-ROM Drive
Go into MY computer and make sure your dvd/cdrw is being shown in there. IF its in there then try to see if it will recognize anything you put in there. Try different things such as a music cd and then a dvd movie. If it recognizes one but not the other then your drive is bad. If your computer is not seeing the drive at all then it could be a virus or your cables need to be reconned to the drive. No driver is needed, just software to burn stuff and a dvd player to play dvd's.
Jan 27, 2009 | E-Machines emachines (emachinees) CD-ROM...
CD drives
hmmm..that buzzing is usually when the cd or dvd is not seated well in the's really a rattle from the drive attempting to seat properly
open the tray, inspect it for any materials that are not supposed to be there
or try another cd, perhaps..
Mar 25, 2008 | Dell (0Y435) Internal 24x CD-ROM Drive
Cd player
does this happen on any game? Or just a one game. Make sure this is not a copy game. GL
Feb 20, 2008 | E-Machines emachines (emachinees) CD-ROM...
Cd/ dvd drive burned out
If it is 5 months old, get it replaced from Dell. Dell's laptop CD/DVD drives are a cinch to replace. Just a couple screws if I remember correctly.
I had the same thing happen to an Averatec AV3715-EH1 notebook, but it was well out of warranty. Had to buy a new DVD burner drive.
Jan 01, 2008 | MSI (MS-P8148-050) (MSP8148050) CD-ROM...
DVD drive some time works, some time does not
first try uninstalling the dvd drive go to start/control panel/system/hardware/device manager look for dvd/cd-rom drives right click dvd - uninstall reboot afterwards so winxp will re-install drivers if this does not work, go to look for downloads for your dvd/cd drives just make sure you have the right model so the file you download will be exact and correct
Jan 21, 2007 | Toshiba Satellite Satellite 5200 Series 15...
HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive Logo
77 people viewed this question
Top HP CD Drives Experts
Brian Sullivan
Brian Sullivan
Josh Whitehead
Josh Whitehead
Are you a HP CD Drive Expert? Answer questions, earn points and help others
