FixYa.com
Tags:
Ultimate Chopper 0.75 Food Processor
Blade will not release (by 2 users)
posted by kstreet245 on Nov 16, 2007
My Ultimate Chopper has worked fine for weeks, then suddenly the blade will not release. The release button depresses, but the blade does not come free and cannot be lifted off. As a result the bowl can't be removed either. It's almost impossible to clean it like this, so the chopper is unusable. How can I get the blade off?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by CarolJeanne, posted on Dec 07, 2007
My Mom had the same problem so she forced it until it came out but it broke. Does anyone know where to get a replacement?
Best Solution
posted on Jan 06, 2008
FixYa! (100)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Our blade just came apart at the seam just above the blade, so we know what's inside. There is a small v-shaped piece of spring wire that is spread apart from the stem that is mounted to the machine. When the button is depressed (it's on a tiny spring, like a mattress spring, and that's what makes it bouncy), it spreads the v-spring wire and releases it. If you can get the seam apart, it will release the v wire and not damage the machine. Replacement blades are available on-line for $13.95, and whole machines are available on e-bay. Good luck.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Food Processors problems?
glass top [cover] is broken
wher do i get a top to buy Answer This...
Ultimate chopper replacement...
Are replacement parts... Answer This...
Ultimate Chopper - need spare...
Model # C-H1-600 Looking for... Answer This...
CH-1 ultimate chopper
Rubber bushing in blade base is... Answer This...
I received a Cuisinart food
I received a Cuisinart food... Answer This...
Repair Service
Find Food Processor Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
