Question about Wagner Power Products 0154842 Medium Spray Gun Filter, 50 Mesh
Wagner Power Sprayer will not lift paint from the plastic bottle into the sprayer. Unit powers up fine. All ports appear to be clear when blown with compressed air. It will not even lift water. Any suggestions?
    New Friend:
1. piston may be bad. There are still parts available - Sears parts direct
2. Disassemble and clean the unit - start by unscrewing the spray tip and keep going until you find the piston. The piston may have stopped pumping due to dried paint or stain inside.
Posted on Sep 22, 2013
  • 154 Answers
Pump may be bad on sprayer or gasket on it
Posted on Aug 03, 2009
Paint cup wont release from nozzle
My suggestion is to soak your sprayer in warm soapy water for 10 to 15 minutes and then try and unscrew it. I think that should soften the paint up enough to do the job,.
Aug 23, 2015 | Wagner Spray Tech PAINT READY SPRAYER
What cain of oil a cant uuse for wagner 1250 hp
Your Wagner 1250 is a diaphragm airless sprayer, which uses hydraulic oil to push the diaphragm, so the oil must be hydraulic quality as it gets quite hot; don't use any other type. The Wagner part number for their quart size is 0088009
Jun 15, 2015 | Wagner SprayTech Wagner Airless Paint...
Does a Wagner Paint Crew sprayer take lubricant?
The Wagner Paint Crew airless sprayer does not require oil for its operation like full professional sprayers. The piston is off-set from the pump chamber with the inlet and outlet valves opposite each other, however you need to protect the parts from corrosion between use and Wagner recommend running some light oil through it after cleaning. If you will be using it in a day or so for water based paint, you could run a 10% solution of their EasyGlide through it.
Sep 30, 2014 | Wagner Spray Tech Wagner Paint Crew 2750...
Spray gun problems
You basically have what is called a "cupgun" and there are a few reasons for this and it should be pretty simple to fix I want to stress that anytime you spray the paint no matter what latex-oil needs to be thinned with the compatible solvent water for latex paint thinner for oil/Alkyd by about 10% - 18% that could be the problem if you have latex in your gun but probably it has to do with the "needle seat" in the back of the gun there should be a knob to adjust the needle turn your gun on pull the trigger and turn knob till paint comes out if that wont work you may have debris in your paint that has clogged the stem pour all the paint out clean gun completely pour paint threw a strainer cone or strainer bag and be sure to thin it...
Sep 01, 2014 | Wagner Paint Sprayer. Flexio 570 HVLP...
My Wagner paint ready sprayer will not spray paint
I'm sorry to hear that the container is stuck to your sprayer. Besides a bad thread or cross-threading, there isn't really any reason the container would be stuck - unless paint had been left in the gun long enough to cause it to dry. call 1-800-328-8251 and they'll do our best to assist you with this.
As a note, the Control Spray Double Duty is a thin body material sprayer for things like stains, sealers, varnish etc. Not for thick latex materials, which I suspect is what you're applying to the wall and ceiling. Not that this would cause the container to get stuck on the gun, but I wanted to point out that this gun probably isn't the best for the project you are tackling.
Aug 12, 2014 | Wagner Spray Tech PAINT READY SPRAYER
Where is the serial number?
The serial number for this is not stamped on any part of the gun it is with the warranty paper work next to the model #
May 12, 2014 | Wagner SprayTech Paint Sprayer. Flexio 590...
My sprayer has power and blows air but no paint comes out
you have old paint that is pluging the pick-up line. you need to clean your sprayer very well each time you use it. I hope this helps you out some.
Aug 14, 2013 | Wagner SprayTech Paint Sprayer. Flexio 590...
Old Wangner Cap Sprayer & Compressor
The Wagner Capspray 9000 HVLP is about 20 years old, but you should be able to find parts, at least for the HVLP gun. The manual for the turbine is #0276989. If you are in the US try Scott at American Airless Wagner Titan Graco Paint Sprayers or in Europe try us at:
Home Lion Industries
Jul 28, 2013 | Wagner Spray Tech Cap Spray Paint Sprayer,...
Wagner Power Products 0154842 Medium Spray Gun Filter, 50 Mesh  Logo
2,212 people viewed this question
Top Wagner Air Tools & Compressors Experts
Jim Parker
Jim Parker
JOHN LAPIER
ray gallant
Are you a Wagner Air Tool and Compressor Expert? Answer questions, earn points and help others
