Water ends up on floor rather than in machine
When washer tries to fill with water, the water comes out the back and bottom of machine. How do I remove the panels to access the internal water connections. When I access the lines, what could be the problem?
  • 975 Answers
It could be a broken hose , use a flat screwdriver to open panels , most of washing machines panels are clip on , hope it helps , AJ
Posted on Jul 13, 2009
Bosch WFVC6450UC Washer leaks at bottom
How about loose fill hose connections?
How about incomplete shutoff of the internal fill control valve between wash cycles?
Sep 22, 2012 | Bosch WFVC6450UC Front Load Stacked Washer...
Water draining from bottom of washer when I went to fill up. Completely drained all over floor within minutes. What the heck is going on?
Have you checked your hoses in the back? The water may be going to the floor instead of the washer. Check around the water pump as well.
Mar 05, 2011 | Maytag Atlantis MAV6451 Top Load Washer
Very little hot water runs in tub
you either have a problem with the house water supply going to the washer and you can remove the hot water hose from the washer,first shut down the water,stick the end of the hose inside the washer and turn the water supply back on,if the water comes out normal then you have a bad water valve on the back of the washer.call your parts store and give them the full model number off of the washer,open the lid,follow it down to the bottom and right under the bottom of the lid you'll see the model number
Jan 23, 2011 | Kenmore 24032\24036 Top Load Washer
My washer won't drain & there is a burning smell. I tried all other functions and none of them will do anything ie won't fill with more water. We bought this washer 1 week ago when our old washer did...
I'm assuming it is a used washer.
First you need to get the water and wet clothes out. Dip it out if you have to, or take the drain hose out of the drain pipe and let water out of it by laying it on the floor, that is only if you can stick the end out the door to the outside, as this will drain the entire tub, or it there is a floor drain nearby. Do not just drain it on to the floor unless you know it won't hurt anything to have water running everywhere.
Once you get the tub drained, you need to check the belt which is on the bottom, accessed either from the back or from the bottom. If it is bad, replace it and try to wash clothes again, be sure you don't overload the washer with too many clothes.
Sep 03, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
The water will stay inside washer tub
Hi, What is the make/model# for this machine?
Did the water come out onto your floor?
I want to help.
Vic
Jun 20, 2009 | Washing Machines
Kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
May 31, 2009 | Washing Machines
Water leaking from bottom
Replace water pump. Common problem. Unscrew the control panel ,two screws on each end. Flip control panel over and unsnap gold brackets from base to the back. Lift up housing and disconnect lid switch, remove housing. The water pump is in the front lower that has two hoses , disconnect hoses and unsnap pump. My sister fixed hers in about 25 minutes.
Apr 06, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Water leak at door but seems to come from door itself.
no seal in outer door, but that's what you need outer door frame about 300.00 , labor 152.00 buy service smart agreement from sears it will cover parts put to 500.00 it will fix it "less soap plz"
Nov 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer is filling up with to much water...
possible fill valve is sticking open when filling after starting washer disconnect power and listen to see if water is still running in if so replace fill valve.. if water stops possible water level switch or small hose to switch plugged ..drain washer remove screws on each side of door frame front will pull off...small hose on some models was attached to pump housing and would become plugged with lint ckd for restriction in hose from bottom to top remove screws in console to acess other end attached to pressure switch
Aug 16, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag top laoder stacked washer LSG1000
If it only leaks in drain it has to be a hole in the drain hose or a plugged up house drain.
Dec 15, 2007 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
