Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Mitsubishi WD-62525 yellow blinking status light
I replaced the bulb because it went out and then the yellow blinking status light keeps blinking and wont stop. I tried resetting and unplugging the tv 3 times but it wont turn on.
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
Posted on Jul 16, 2009
  • Gus Vazquez
    Gus Vazquez Dec 24, 2013
    Outstanding. I checked it while on this particular page/site and it turned out to be precisely that. Despite the fact that my girlfriend tried to tell me that the door might have a sensor which didn't allow the light to go off and the tv to go on, I didn't listen and chose to check online. Now I have to apologize and give the due credit, along with this wonderful site and solution. Thank you very much....
    New Friend:
Where is the air filter door at
Posted on Mar 21, 2014
WD-62525 went dead. Can a burned out lamp cause this?
No, a burned lamp would cause the power source of the tv to go in reduced mode and that would be clearly identifiable by the blinking lights on the status and lamp indicators.
If the tv is dead (no lights whatsoever)it means that the power source has failed completely - this is a big defect, that must be investigated by a pro: the origin of the failure must be found and the faulty part replaced replaced or any new part you just put in blindly will be instantly fried. At least the power source board will have to be replaced and that will cost you around $250.
Jan 03, 2011 | Mitsubishi WD-62525 62" Rear Projection...
I have a yellow blinking light after replacing light bulb
Either the lamp door isnt secured properly or the vent cover is open.
Oct 03, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Timer light blinking fast and is green, Tv will not turn on even after a reset, bulb is good
First mistake was buying Mitsubishi Model WD-62525
The DM capacitors need replacement contact a local Mitsubishi Model WD-62525repair center.
Jan 23, 2010 | Mitsubishi WD-62525 62" Rear Projection...
I have a WD-62525 TV and I was getting a message
The lamp cover isnt secured properly that what causes the staus light to blink yellow.
Dec 30, 2009 | Mitsubishi WD-62525 62" Rear Projection...
WD-62525, continous amber lamp light. No picture. Lamp is good.
Hello:
Make sure u replace the lamp cover as the safety switch need to be closed to make the set work. If new lamp did not repair your problem , then it may well be the Ballast Board, Sometimes call the Lamp Driver.
Nov 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
TV was working earlier, today came home no green power light no nothing
I looked up the manual online - after you replace the bulb, you need to reset the bulb life timer. Using the TV remote push the menu button, SETUP menu, select the lamp reminder option to reset the hours to zero. That might help the status indicators.
Sep 04, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi 62" dlp wd-62525
The lamp is either defective, not connected properly to the wiring or plugs (careful alignment required on the two connections), wrong type bulb, or the front panel is not replaced properly to trigger the panel sense switch (lower right side of panel)
Sep 02, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
4,193 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
