Question about Nokia N70 Cellular Phone
Vry strange prob...
I by mistake deleted all my messages on MMC card & there r no messages on phone memory.......waz nt able 2 recover it.....connected my phone 2 PC via data cable.......on PC suite 'Messages' i can view all d deleted messages in inbox, outbox, sent items( witout d MMC card in cell).......Y tis is happenin??? & can i recover d other messages in my folders(they r vry vry important 4 me) me.......i wan2 recover My folder messages.......
  • 72 Answers
Re: vry strange prob...
  • 30 Answers
I HOPE IT WORKS and don't forget to rate me SOLVED.
Posted on Nov 24, 2007
0 characters
3 Points
Is it possible to recuparate a message that i erase by mistake? thank you
Hello there, sorry but there is no way to recover deleted messages from a memory card or a phone. If it was a hard disk there is a way but memory cards do not leave shadows of documents on the card which should help in the recovery of deleted files. Sorry for any inconveniences.
Thank you for visiting FixYa.
Sep 06, 2011 | Cell Phones
Recover deleted messages stored in samsung gts5230 internal memory not in sim card
First thing to note is that the deleted data on the phone will remain there until something new is saved and overwrites it. This might not happen immediately but eventually, after continued use, it will.
Either connect the phone straight to a PC using a USB cable (if supplied with the phone) or take the card out and put it in a card reader attached to the PC. You should see memory card shown as a drive letter (like H:) in Windows Explorer.
Then try some data recovery software on the PC. This should recognise the phone or card and then you can scan it using the free download of some good data recovery software. That will show you what files still exist on the phone or card and what can be recovered.
Sep 02, 2011 | Samsung Star GT-S5233 Cell Phone
How can i recover deleted text messages, photos, and other files from my htc t3333? thanks!
If you have a memory card for your mobile phone,your data is saved on the memory card.And you can recover deleted data from the memory card with memory card recovery software.I had succeed to recover deleted photos from memory card of my phone with Asoftech Data Recovery.You can get it from
Dec 23, 2010 | HTC Touch2 T3333 (UnlockedNo Contract) PDA...
Can i recover deleted text messages from a samsung omnia? the messages never appeared in my deleted file but are gone from the inbox
You may try this mobile phone data recovery software which helped me before. You can download trial for free
Please be noted that your phone memory should show as a drive letter in your explorer, if not, you need to take out your memory card and connect using a card reader, or plug-in to card reader slot if there's any on your computer.
Sep 09, 2009 | Cell Phones
Settings received but not saved. message deleted
1. The phone may not have enough memory to save the message. This may be one of the problems. You say that you have just formatted the phone and card memory. The memory card may not be formatted well. Be sure that the memory card in the phone is accessible and can be read.
And you say that you formatted the a few days ago. Maybe it is full. Please check it. Because your downloaded messages may need extra space.Check the message settings where to save.
2. The other problem may be the multimedia message settings.
- Select Messages > Options > Settings > Multimedia message.
- Check the settings for multimedia messaging. It must be defined correctly and be sure that there is no mistake in phone numbers and addresses.
3. If you installed any application and even if you installed that application to PC or memory card, the installation files (.sis) of applications that are stored in the phone memory remain in the memory. Remove such installation files from the device memory.
After backing up the installation files if there is any, delete the installation files using file manager.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Jun 29, 2009 | Nokia 6225
How can I recover deleted texts on the samsung eE720
you can use a file recovery program to recover deleted text from phone. I had success with this program called asoftech data recovery, you may find more info from
Apr 20, 2009 | Samsung SGH-E720 Cellular Phone
Showing memory full
the bestb thing to do is formatt your unit, and the MMC'
after you have formatted the MMC in you phone,
set you massage in setting>other>select MEMORY in USE' put in MMC in use. so all uyour massage will directly save in MMC even it has High mb/kbs...
Mar 11, 2008 | Nokia N70 Cellular Phone
Memory card problem
i think the MMC card is the prob' try to format it first, if you still having the same prob.
try to change MMC....
Mar 08, 2008 | Nokia N70 Cellular Phone
My meomry card is not working
1.... try using a differnt MMC .. to check that the problem is in ur MMC or nt
 2..... the first reason may be   u have locked  ur MMC  u can only unlock it if u remember the password
 3... if above mentioned is nt the problem then  ur MMC is corrupted .. so u need to format it , can use  MMC reader for this process ............
Sep 04, 2007 | Sony Ericsson K750i Cellular Phone
Nokia N70 Cellular Phone Logo
181 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
