Question about Patton Electric Dryers
Patton 20 inch fan stopped working, is there a fuse in it?
Patton 20 inch fan mounted over my horses stall.Two were bought at the same time. MY fan stopped working
3 Suggested Answers
  • 4 Answers
SOURCE: Bad Switch / Patton 20'' fan
call 1-800-284-3267. have your model and serial number, and all other numbers on the tags. Plus the numbers on the power connector prong. They might send you a new switch or replace the fan for free.
Posted on Dec 14, 2009
  • 185 Answers
SOURCE: i want a new motor
You can generally find new motors at an electric motor shop, check the yellow pages. However they are many times more money than a new fan. Then add time and your drive to get the motor, my recommendation is purchase a new fan, cheaper in the long run.
Posted on Feb 23, 2011
The Patton Floor Fan I have quit working when a shirt was sucked into it and no-one was home. I am wondering if they have a fuse on the motor that can be replaced?
Most have a one-time thermal fuse wired into the motor. You would have to remove cage and fan blade, unscrew motor mounts, open motor casing, locate fuse by cutting open or sliding off the thermal sleeves, cut fuse out and resolder a new thermal fuse in. Should be able to locate replacement thermal fuse online. Can also just splice ends together but then you lose thermal protection and a fire can result. It is a good temporary fix to diagnose if you have burnt out one of the motor coils.
Oct 01, 2014 | Patton Dryers
I want a new motor for the patton 20'' cvt air fan
Feb 23, 2011 | Patton 20" CVT Performance Air Circulator,...
My 20" Patton electric fan has stopped working. I use it for animal cooling and it operates in dusty conditions. I suspect that the motor is shot. Is it worthwhile to replace the motor and are motors...
You could just try to clean the motor out by taking it apart, and shining the shaft up. then put some motor oil/engine oil on the shaft. That will work 99% of the time.
Aug 12, 2010 | Vacuums
Need new motor for Patton High Velocity Air Circulator Model G-1272, 110 current. After about 27 years, the motor quit. This fan is a wall mount behind my wood/coal stove facing the stove pipe. It has 3...
Do you know where I can get a replacement knob that goes on the back for low, medium and high setting? It came off when I was moving and is difficult to turn without it (i use a screwdriver at the moment).
Jan 11, 2010 | Patton (HASF1016UC) Stand (Pedestal) Fan
Fan keeps cutting off after being taken apart and cleaned
If it was wired wrong it wouldn't run. I would suspect uneven tightening of the motor screws.
Aug 08, 2009 | Patton Electric U2-20 Box Fan
Fan blade for a U2-20
I have a metal blade for the Patton U2-20 fan listed on ebay. The item number is 160273949463 and the listing ends on Wednesday August 27 at 10.00 p.m. I had this fan for 8 years and the motor has failed. Patton could not replace the motor since this is a discontinued item, and I figured that someone could use another blade for their fan. I hope this helps you!
Jun 27, 2008 | Patton Electric U2-20 Box Fan
Patton fan motor
I found something on amazon, take a look here: Emerson Fans Moving Air In Style . I hope I have helped. Cheers
Sep 17, 2007 | Rival U2-1403 Fan
Dryers Logo
495 people viewed this question
Top Patton Electric Dryers Experts
Darrell
Vernon Taylor
Andrew Taylor
Andrew Taylor
Are you a Patton Electric Dryer Expert? Answer questions, earn points and help others
