How can I get my Canon Scientific Calculator (F-788dx) to show comma instead of a dot for decimal symbol? It's because I want to set it to display the European style.
I don't think you can change the display. I looked in the manual. Hopefully, some day, this will be available.
http://www.canon-ebm.com.hk/download/manual/F-788dx/F-788dx%20English_P.pdf
SOURCE: reset?
Okay, I did what the best solution did and worked with it.
"1. press 2nd F (left top corner)
2. ENG/FIX (the button next to 2nd F)
3. press 0 (if you don't want calculator to round off any decimals)"
In order to get your exact value of pi, in step #3, instead of 0, press the decimal [ . ]
This should give you no decimals when entering a number and give you 3.141592654... when you input pi.
Hope that works/helps.
SOURCE: Canon F-502 statistycal scientific calculator
As I added on to the previous solution on the other problem.
"Okay, I did what the best solution did and worked with it.
Hope that works/helps."
SOURCE: EL-1197PIII Sharp Calculator
move switch for decimal places to "add",or to number "2" for 2 fixed decimal places
SOURCE: how to reset a canon F-604 scientific calculator?
Press [ON/C] and [0] together. Memory will get erased, number base is set to decimal, and display format is reset to floating point.
SOURCE: I have the Canon LS-100TS
Try switching between business and tax mode, the little toggle switch at the top of the calculator.
If that doesn't work repost.
Hope that helps
