Question about Kodak EasyShare Z885 Digital Camera
My camera turns on, then immedeately shuts off. I
My camera turns on, then immedeately shuts off. I have a fresh battery and I cleaned the battery contacts. It was not dropped or exposed to water. It is a Kodak Z885.
    Genius:
  • Kodak Master
  • 1,099 Answers
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Make sure that you are installing a fresh/ full charge battery
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Oct 30, 2009
Camera wont turn on even with fresh batteries
camera wont turn on even with fresh batteries,it says:"battery low..than beep,beep and turn off"
Jan 21, 2010 | Kodak Easyshare C813 Digital Camera
The Focusing ring BUZZES and Shuts off
1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable. 4. The alternative is a repair. Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 14, 2010 | Kodak EasyShare M1093 IS Digital Camera
Kodak easyshare m340 turn on lens come out then shuts off
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Camera turns off then quickly shuts off.
Here are the steps:
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
Nov 13, 2009 | Kodak EasyShare M863 Digital Camera
When turning on camera the lens will open then shut off on a fully charged battery. It will allow you to view pictures on the camera by selecting the favorites and turning it on but when you turn the...
Remove the battery
Your batt. is covered under the same man. warranty as your camera.
Contact KODAK:
Nov 05, 2009 | Kodak EasyShare M863 Digital Camera
Camera gives this warning quite regularily then shuts down. usually when i first turn it on. kodak easyshare dx 7630 jaberwoky7@hotmail.com
If your cam use AA batt.:
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Remove the battery
Contact KODAK:
Nov 01, 2009 | Kodak EasyShare One Digital Camera
Easy Share V1003 Turns on, then shuts down.
Remove the memory card and the battery
Contact KODAK:
Aug 23, 2009 | Kodak EasyShare V1003 Digital Camera
My camera turns on than turns right off
Remove the battery
Contact KODAK:
Jun 05, 2009 | Kodak EasyShare Z885 Digital Camera
My camera turns on then quickly turns off.
This is usually a low/bad battery problem. Remove the batteries from your camera and make sure the battery and camera contacts are clean. If using alkaline batteries, try a fresh set. If using rechargeable batteries, recharge them for several hours. If a recharge doesn't work, you may need a new battery set. eBay is a good source for reasonably priced replacement batteries.
Bill B.
San Antonio
May 16, 2009 | Kodak EasyShare DX6490 Digital Camera
Fuji FinePix A400
Take the batteries out and clean the contacts
Those at the bottom of the battery compartment you can clean with the eraser at the end of a pencil
do the same with the lid.
Make sure the batteries are fresh/charged
When you close and lock the compartment lid squeeze it shut then turn on- it may be a contact problem.
If this fails then it will be a repair shop job
Dec 07, 2007 | Fuji FinePix S3100 Digital Camera
Kodak EasyShare Z885 Digital Camera Logo
280 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
