Question about Jenn-Air JGS8750 Gas Kitchen Range
Gas oven on freestanding Maytag MGR5730BDW range keeps relighting
I have a maytag freestanding range that is probably about 10 years old. It as electronic ignition and recently the oven has been constantly lighting and flame going out and then relighting again. Happens every 2 seconds to 30 seconds as it is preheating and probably every minute or two afterwards while cooking. Using other gas appliances in the house makes no difference. It also makes a weird purring or puttering sound that is more noticed when you first turn it on. It also mellows out and doesn't sound as if the flame is getting blown out and runs more normal when you turn a top burner on while oven is operating.
catriver
  • 878 Answers
SOURCE: Igniters won't stop poppong
Sing, sounds like you got one of your burner valve switches wet and it's grounding out. Try taking a hair dryer, pull of the burner knobs and going lightly over the control valves. The switches are mounted to these valves. It just may need to be dried out. If this doesn't work, one of the switches shorted out. Catriver..post back.
Posted on Sep 11, 2006
catriver
  • 878 Answers
SOURCE: Oven Burner turns off during preheat
Mike, I think your problem is in the ignitor itself. Turn the gas off and see how many amps it's drawing during the bake mode. It needs between 3.2 and 3.6 amps to keep that valve open. Then ohm out the temperature probe, appox 1132ohms at room temp. You can see if your electronic control will go into a quick test by pressing and holding the cancel and broil buttons together for 3 seconds. First kill the power to the range and power back up before entering. When quick test appears you can check the bake relay by pressing bake. The relay should activate and 1 should be displayed. Same thing for convection bake except the fan should run too. Catriver...post back.
Posted on Feb 25, 2007
jsrock516
  • 5911 Answers
SOURCE: jenn air jgr8850adw won't bake
This usually is an indication of a bad igniter. If this is the standard glow type igniter, it could appear as if it is working, but may not be providing enough current to open the gas valve. This is a safety feature on gas ovens. The gas valve requires a current potential of .32 to .37 amps through the igniter before it will open and allow gas to flow. This prevents gas leakage if the igniter fails to light. The reason your broiler works is probably due to the fact that the broiler gets used less and the igniter is probably in better condition. You can test this theory, if you like, by swapping the igniter for the bake and broil burners to see if the symptoms change. Or, you can simply just replace the bake igniter with a new one. Make sure you secure the power before attempting, though. You shouldn't have to turn off the gas for this. Chances are that's all it is. I hope this helps you.
Posted on Jul 14, 2007
SOURCE: Igniter continuously clicks
I had this problem. It was caused by the burner "thinking" the flame had turned off--it was clicking because it was sparking to re-start the flame from the gas. I was able to fix it by tightening a flat, thin nut at the top of the burner.
Posted on May 22, 2008
  • 126 Answers
SOURCE: GE gas stove the burners on top work, the oven won't get hot
The most common reason a gas oven won't heat is a bad igniter. It is located near the valve and burner under the oven bottom. You can usually see it glow orange just before the fire lights. Most GE ranges take a cylindrical igniter part #WB2X9154 or #WB13K21 rectangular igniter.
Posted on Jan 02, 2009
Maytag gemini range
Don't keep resetting the breaker, you have a dead short and you could burn your house down, call an electrician.
Jul 22, 2016 | Maytag Gemini 30" Self-Cleaning...
Broiler shuts off
Make sure you keep the oven door OPEN when using the broiler, otherwise the thermostat will shut it off.
Jan 18, 2013 | Maytag Gemini MGT8655X 30" Freestanding...
Maytag MGR5730BDW gas range oven do not bake, the automatic pilot turn on but burner bake don't start
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 04, 2011 | Microwave Ovens
I have a Maytag gas stove model MGR5730BDW. The oven won't light. The broiler works just fine. The bottom ingiter glows orange and gets hot but the burner won't light.
Hello, Thank You for using FixYa. I will be helping you today.Just because the ignitor glows does not mean its good..switch the two around and see if the oven comes on. They still glow even when they start to go bad.
Thank You and please rate my answer if it was helpful..
Jun 16, 2011 | Maytag 30" Self-Cleaning Freestanding Gas...
Where is the pilot light for the oven on a maytag MGR5730bdw
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has failed...
Yeah it sounds crazy, but read this..
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Apr 17, 2010 | Jenn-Air JGS8750 Gas Kitchen Range
Lost manual for self cleaninf Maytag oven. It's about 8-10 years old.
My answer is to NOT use that feature, as generally after most people use that :Feature" straight after the oven faults, you see that "Cleaning" mode simply heats the oven up wayyy up to like 900 degrees up, and after this the temperature sensors generally "Go" so my advice is ... use elbow grease and save a lot of possible problems, especially with a 8 - 10 yo unit.
Mar 16, 2010 | Maytag Gemini 30" Self-Cleaning...
How do you clean the self cleaning oven i never got a book
just push the clean button, it will superheat the oven for an extended period, burning off old residue.
Apr 12, 2009 | Maytag Gemini 30" Self-Cleaning...
Maytag gas range I'm not sure of the model #/range is nine years old
YOU OVEN IGNITER IS PROBABLY ONE STEP AWAY FROM GOING OUT.
SO REPLACE IT AND YOU SHOULD BE UP AND RUNNING.
Jan 15, 2008 | Maytag MGR5751AD Gas Kitchen Range
Jenn-Air JGS8750 Gas Kitchen Range Logo
281 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
