Question about Vizio L37 Television
Help when i play a dvd movie i get no color, just black and white other than that tv works fine. i'm 99.9% positive it's the television. I just got it, and proir to this tv set I had no propblems with color. thanks
  • Anonymous Nov 20, 2007
    I have the same problem
    Novelist:
  • 111 Answers
Test the dvd player on another tv to insure it is working, use the same cables you are using right now.
check the connector, if you are using s-video there may be a broken wire or loose solder joint to the pin.. i would start by replacing the cables and see if it clears up the issue.. if not, check the tv settings and make sure the av inputs are set to pal/secam/ntsc depending on you region and the output of your dvd player.
if your tv is equipped with it, make sure the input channel is correct (should be under settings in the menu).
hope this helps,
trin
Posted on Nov 16, 2007
Vizio tv - plays fine and in color. hooked up phillips dvd player - all connectors connected correctly. when i play the dvd, it is only in black and white . . . not color. how can i get my dvd to play...
Which input on the TV and which output on the DVD player are you using? HDMI is the best and easiest. Next is standard video plus audio (3 leads, yellow - video, red and white - audio). If you are using the component input, you can get B&W if you have the leads incorrectly connected. If you're going from component to video in, you might have the same result, I'm not certain. I hope this helps you resolve your problem. Let us know.
Mar 23, 2014 | Vizio E601I-A3 60-inch Class Razor LED...
When playing DVD on panasonic plasma TV, the color is black and white
Consult the owner manual for the player (and or try it on another set) as many players have settings that can cause B&W or a single color display for the image.
Dec 02, 2012 | Panasonic Viera 50" Class 1080p Full HD 3D...
My dvd player only plays movies in black and white
my dvd player only plays movies back in black and white...not color. why?
Jan 21, 2010 | Cyberhome CH-DVD 300 DVD Player
New lcd tv and dvd player is playing movies in black & white
1. Verify connections are color coded.
2. If they are correct, take out movie, press Play/Stop at same time on the front of the unit (not remote) to reset any settings that may have been changed.
Jul 04, 2009 | Coby DVD-536
DVD won't play in color
Had the same problem. It turns out my cables that go from the dvd player to the tv were bad. Did you try using other cables? If not, try it out.
Hope this helps.
May 09, 2009 | Sharp LC-32SH12U TV
DVD player in black and white
Ok I know I just made a comment but guess what... heres the solution!!!!!!! I was sooo mad that I went and started playing with the cables and got it working. You have to plug in white to white, yellow to green and red to blue on the back of the DVD player and match up the colors on the back of the tv. And it plays in color!! Hope this works for you too!
Jan 04, 2008 | Disney 13" TV
Playing movies in black and white
Use a scart lead to connect it to the TV, that should cure it.
Dec 08, 2007 | Sony DVP-NS315 DVD Player
DVD PLAYER PLAYS BLACK AND WHITE
sir/maam it is possible that the DVD player is not compatible with colored tv,s or one more thing is kindly first adjust the screen focus of your tv,,,,thnksss and hope to help you!!!more power
Nov 25, 2007 | Toshiba MW20F51 20 in. TV/VCR/DVD Combo
Vizio L37 Television Logo
79 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
