Question about LG Televison & Video
IT DOES NOT TURN ON BRAND NEW AND IT DOES NOT TURN ON THE LIGHT STAYS RED
    President:
  • 1,077 Answers
Normally, when this happens, the TV goes into " Protection Mode " because of a failing circuit board. Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. Or, it maybe something simple like a blown fuse inside the TV. But, I can't say it's 100% the problem because I can'tactually look at the tv over the internet. I can only make guesses with the symptom.
You have a few choices:
1. You can try leaving the TV unplugged for 30 minutes so the TV can reset itself.
2. Given the info that the TV is brand new, the TV should still be under warranty. I would go that route.
You shouldn't have to pay a dime to get it fixed.
I hope I shed some light on the subject for you.
Posted on Jul 13, 2009
Why does plasma TV have no picture?
What brand and model # is the tv? This is very important as far as researching your problem. You probably aren't the first or the only person with this problem. There are typically four to 5 boards including an x main, a y main, power board and others. Sometimes easy stuff like capacitors or fet's go bad and you can fix it yourself pending your soldering abilities. Sometimes whole processors go bad or entire boards and these need to be replaced. Sometimes people want to fix sometimes they want brand new
Jul 07, 2015 | Televison & Video
Can't take picture or record video?
Try turning the screen all the way around and close the screen so the screen its left outside where you can see if that doesn't work you will need to replace the ribon that connects the screen to camcorder.
Jan 30, 2014 | DXG Technology DXG-506V DV Digital...
Tassimo problems red light
T47 . sometimes Red light stay on after instaling the creamer disc
Jan 03, 2014 | Coffee Makers & Espresso Machines
How to program a new tv to remote
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Jul 23, 2012 | Insignia Televison & Video
The red light is always on, and it doesn't seem to be charging. Its almost brand new.
Same thing started happening to me. The red charging light was initially going out but then after a few days use started staying on. I assumed that the battery was damaged and bought 3 new batteries but the red light is still staying on when I charge the new batteries.
I suspect that the mains charger I was using (same voltage but not the recommended charger) has perhaps damaged a component inside the EFLC1003 unit which is now not letting the power through to charge the battery.
Dec 30, 2010 | E-Flite 1s 3.7v Li-po Battery Charger Mcx...
I just got a brand new flip video mino hd and it wont turn on. i've charged it for atleast 4 hours. when it is plugged in the red light comes on. that is the only response i get from it. any...
I had to charge mine for 7 to 9 hours the first time, and make sure computer is left ON or it won't charge and the red light stays lit until it is fully charged. make sure the red light isn't blinking if it is, plug it into a different USB 2 port and don't use extension with it unless it is a powered USB extension.
Dec 28, 2010 | Pure Digital Flip Video Ultra Camcorder
89 Honda Accord Battery Light is On
The FuseLink is blown. It is a 100 AMP in-line fuse on the red wire from the alternator.
Oct 05, 2009 | 1989 Honda Accord 4 Door
Motorola s9 headset not charging
I had the same problem but instead of a red light it would flash green twice and stay off. I could not find the original charger and another plug in charger would not work. I plugged it into my computer with a usb cable and after several seconds it started charging.
Sep 16, 2009 | Motorola Mobility S9 Headphones
Led light constantly stays on remote rcr4358
First off, put in brand new batteries. Not just batteries that are kind of new, i mean BRAND SPANKING NEW batteries right out of the packet.
If you still have a problem:
~hold down the DVD-VCR button-> the red led will stay lit.
~holding down the DVD-VCR button press the number 2 --> the red led will turn off
~Release the DVD-VCR button--> the red led blinks 4 times and turns off.
Hope that helps!
Rate me!
Feb 11, 2009 | RCA Universal Remote Control
Panasonic TH-42PX80U won't turn on.
You are missing 15volts. If this is a new TV, it could be as simple as a plug not fully seated on the power supply. Regardless, the repair should be covered by warranty and Panasonic is one of the best when it comes to taking care of the customer. Ifd nI can be of further assistance, let me know
Dec 21, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Televison & Video Logo
221 people viewed this question
Computer Repairing
Computer Repairing
