Question about Sylvania SRD3900 DVD Player/VCR
Record I lost my manual and i want to know how to set timer to record a show when i gone
  • 111 Answers
I have uploaded the user manual for this model, it should be visible within the next 24 hours. the quick version is this:
if you haven't done so yet, set the clock
menu/ use up/down arrows to select "clock set", press right arrow to select, set day, year, etc using up and down arrows, when each is set, the right arrow moves you to the next bit
once clock is set
timer recording
use up and down arrows to scroll to timer recording, and press the right arrow to select
set the program number (1-8)
set frequency (once, daily, weekly)
set the date to record
set start time (i usually go 5 mins prior)
set end time (i usually go 5 mins after)
set channel number
set tape speed
exit by pressing clear/c reset
press t-set to activate the timer
the timer rec light should come on, the timer recording will not be active unless you press the t-set button
hope this helps
Posted on Nov 16, 2007
VCR Recorder VC-H982 Can't time record. can't select a channel other then 3, 40 av under timer. What is pdc?. where dose it appear. what is sap in set up window? what is air in the channel...
You will probably find a free manual at the Sharp website. That should answer most of your problems. However can tell you that PDC stands for Programme Delivery Control. With it on, say you want to record a program that starts at 9pm and finishes at 10pm. Then all you need is set the control to on, when you set the timer recording, and the video will record your show, even if it starts at say 9.10 and runs while 10.10. The VCR will wait till 9.10 to start and stop at 10.10. Good if a sporting event or live event overruns!
However PDC doesn't work on digital and will not work sometimes at all or if you set the timer wrong. It uses the old teletext signal, which is why if you are in an area that has gone over to digital it should be set to off! As it will never get a PDC signal!!!!
Jun 04, 2011 | Sharp VC-H982U VHS VCR
I lost the owner manual so I don't know how to use it to record. Can you show me how to record it? or tell me the website where I can download the owner manual? My Lorex model is Sg7964
The manual is available here: . The direct link is: .
If the timer is not currently active, then for a basic recording, put in a tape that has the erasure prevention tab in place. Then press Rec/PlaySpeed (up or down arrow) to set the recording speed. If you want to skip the setup steps, press Display. Then press Rec. Press Stop to stop recording.
I hope this helps.
Apr 29, 2011 | Lorex SG-7964 VHS VCR
I need to know how to reset the timer. Right now it says DUSK, what does that mean?
You posted under ST01C Intermatic timer.
DUSK is the dusk-to-dawn option available with astronomic timers like the ST01C.
If the ST01C is not your timer, add a comment with your timer brand.
I have tested the ST01C and many other timers.
To diagnose the timer, press manual override (on-off button) to see if timer operates Load.
The ST01C will not operate the Load if battery is bad, or if timer has gone bad.
Replace CR2 battery, and then re-program current time and day.
Current day settings are lost when battery goes bad, but the on-off programming remains indefinitely inside timer memory until the reset button is pushed.
To clear timer memory, hold down on-off button and push tiny round reset button for several seconds.
The following link shows the manual and EZ steps to reset timer:
The link also shows other timers in case you have a different brand.
Nov 11, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
• After timer recording is completed, the VCR turns off
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
Press SET –/+ to select one of
the program lines, then press
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
Aug 28, 2010 | JVC Televison & Video
How do i record on my go video when i am gone?
hello connect the dvd/vcr to ur pc and change ur setting time and date all .is it is usb connecter with ur product
May 23, 2009 | GoVideo Go Video DVD/VCR Combo
I have trouble taping when i put the timer on it does't tape.
You are looking for a user manual? Is the Sharp VC-A554U VHS VCR the correct model or do you have another device?
Thank you.
Jan 26, 2009 | Sharp VC-A554U VHS VCR
Channel stuck and can't record shows the same night
Your two problems are related - the DVD player lost contact with the local PBS channel, which altered its internal clock.
Add a red, white and yellow cable from one of the outs on the back of the cable box to the slot marked AV1 IN on the back of the Philips. Then redo the channel programming - press the System Menu button and change Tuning Band to CATV - it will then ask you if you want to do an Auto Channel Set - say Yes.
Once it is done with the channel programming, turn the DVD player to whatever channel PBS is on in your area's cable service. Then go back to System Menu - select Clock Set and go to Auto. Alternatively, you can select Manual under Clock Set and change the date by hand).
-Tha Mp3 Doctor
Sep 24, 2008 | Philips DVDR3320 DVD Recorder/VCR
Recorder comes on on its own
I downloaded a manual - previous version lost in a crash - and sorted it out with that
It wasn't the timer but the settings on "alarm playback function"
Mar 10, 2008 | Olympus VN-2100PC Digital Voice Recorder
DVD Recording from Television on DVD and VHS
First off, be sure that you are on the channel that you want to record!!
Press the setup button, the SETUP menu screen appears.
Select "timer rec set".
Then another screen comes up... select "new"
Enter your times, dates, etc.
Dec 18, 2007 | Sansui VRDVD4005 DVD Player/VCR
Toshiba M674 Lost Remote can't change tape speed
Is this an older VCR? If you can set the timer on the VCR itself
like on an older model you can set the timer and set it to record
in another speed. But if you can't do this. You are stuck at
recording in sp. If you can set the timer, if you make just
one mistake it may not come on at all. That's why vcrs
are not as reliable as dvrs. if you don't want to miss a show
diffinatly make sure you re at home and see it come on
like fill up the whole tape and put the show on the end of the tape. like a 2 hour movie comes on a 8pm-10pm set the
timer at ep speed to come on at 4:05pm- 10:05pm and put a 2 hour tape in it. in ep it will record for 6 hours. tape will stop
automatically so you will record it, and it will be on the tape
at the end. that's the way i do it. if I'm not going to be at home
if i really don't want to miss a show at all. because when you set the timer it still might not come on if you see it on you know
its going to record it.
note its cheaper to just buy a new vcr than buying a $72 remote.
you might as well do that if it is a newer model.
I bought an older model vcr in a thrift store for $10 and it worked good for a year for recording shows. I got lucky I guess.
it didn't have a remote I use the timer to set the ep speed
to record.
Nov 22, 2006 | Toshiba M674 VHS VCR
Sylvania SRD3900 DVD Player/VCR Logo
234 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
